Building ITB manifold and plenums off the car
Can someone measure for me the spacing ( across the engine and along the two rows ) between the 4 bolts on each side that hold the lower manifold faces onto the heads.
I want to make a jig to hold an ITB setup , off the car , so I dont need to strip out the running cars existing manifolds to design and build plenums.
Thanks in advance.
Thanks in advance.
Of course not. Not unless they measured for themselves.
Any machinist worth their salt doesn't come on a forum to ask for such key, precise measurements that if off by as little as a mm is a huge waste of time and aluminum.
Hope to be proved wrong.
But somehow doubt it since last log in was over six months ago. And... one can just order a manifold/full ITB setup from OBX or Jenvey. Sure, fabbing has its rewards but this -to me- isn't worth the re-engineering.
mcarther101
Intake
03-18-2014 05:21 AM
