Alignment Questions..
Alright, so I need to get camber arms so that i stop wearing the outside sidewall of my tires whenever i autocross, or do a touge run, and I also am planning on getting coilovers whenever I can afford it.. and i am wearing my tires so fast because of the fact that im wearing mainly the sidewall, and I am going to get camber arms in order to get some solid camber, but I can afford camber arms today, but not coilovers, would it be okay if I got the camber arms without coilovers, and then got an alignment, and then got the coilovers, and didnt get an alignment? or would that seriously screw up the alignment to make me have to get a new one? maybe this is a dumb question, but would apprecaite feedback, thanks!
![](https://my350z.com/forum/images/ranks/moderator.gif)
Which tires are wearing?
Rears can be corrected with adjustable camber arms. You may wish to add offset toe adjustment while doing that.
Front requires adjustable FUCA (front upper control arms) to address camber.
There was a set of rear arms on Marketplace day after your last post on this topic.
Not sure what you're asking WRT installing COs. You want to align now then not have to after cos installed? Uh, no, the resson adding In such components is to be able to adjust alignment in response to any changes in suspension geometry and coilovers will certainly alter that, necessitating alignment,
Tech Territory (06-17-2024)
Be patient. Do it right and do it once. Save a little more and buy all the suspension components all together, install and take it to the alignment shop once and youre done. Instead of buying one part at a time and having to take back to the alignment shop every time your swap something out.
The following 2 users liked this post by travlee:
bmccann101 (06-17-2024),
thats not the issue. its that i am wearing my sidewall. im literally riding on it when im turning hard, so adding coilovers (which im planning on anyways) and camber arms is going to solve the issue if im not mistaken
Possibilities:
(Any/all or combinationsthereof.)
- Tires are underinflated for your use. Autocross and other hard cornering should be higher than stock to help limit rollover. Try the chalk test at varying pressures to dial in your AX settings.
- Front hubs/bearings are toast
- Broken/bent control arms (not that unusual)
- Bent/broken steering knuckles
Shall I go on? Point is, you need to evaluate all of the consequential suspension pieces without wasting time and money on coilovers which will do ZERO to fix your issue since the shock/upright is the last possible suspension component that can cause this type of tire rollover.
By the way, unless you are tracking and willing to spend the $$ on "real" coilovers, (Not to mention learning how to make the proper adjustments - and trust me, not many people do) don't bother.
Fix what's broke first then worry about hip coilovers later.
Tech Territory (06-19-2024)
I agree with Mic. Underinflated tires can be causing this issue. Find the underlying problem first before just slapping on some coilovers which wont do a thing to help your situation
You are mistaken. You said sidewall? If that's true and not just the edges of the tread, there's something SERIOUSLY wrong if your tires are rolling over, damaging sidewalls.
Possibilities:
Possibilities:
Coilovers are something i have been planning on for ages anyways,and my struts are blown so I just decided to spend extra money on what i want, rather than cheap out on something ill replace in the future anyways... and I am going with fortune auto coilovers, and z1 performance upper control arms and traction bars.
You might ask why i would do coilovers if im autocrossing, because it would raise the class im in? My car already has 2 aftermarket sway bars, so I am actually already in a class that allows tunes, coilovers, tires, etc, etc, so it will just make me even more competitive with my class... (Street Touring Ultimate)
Again, I do appreciate the feedback, aswell as trying to help me solve the issue, but its hard to explain what is going on without showing you in person.
First off, i am not just "slapping on some coilovers" to fix it, I am going with coilovers, adjustable control arms, and adjustable traction bars, aswell as a alignment in order to make sure the car is tracking again, and so that I can add a few degrees of camber for maximum grip. And as a autocross guy i have also messed with my tire pressure way too much to even explain, I appreciate the help, and trying to solve the issue for me, but i have also gone through many things that it could be, and this has been my solution after basically checking or replacing all of my suspension components in the front end of the car
nkohler
03-03-2007 11:03 PM
