Front bumper cracks
Old 06-22-2024, 06:08 PM
jmosh25
jmosh25's Avatar
Question Front bumper cracks
I recently picked up a 2004 Nissan 350z and the front bumper has punched holes near the top with zip ties going through them. After looking closer it appears that the bumper is actually cracked in these areas and I'm assuming the previous owner zip-tied it to keep the bumper in place. Also, there is a crack near the grill area. I could be normal and buy a new bumper and dent my wallet. But I want to know if y'all have any restoration ideas that could work. If not, recommendations for replacing the bumper would be great too!
Old 06-23-2024, 05:35 AM
dkmura
Premier MemberSuper Moderator
dkmura's Avatar
Received 1,311 Likes on 910 Posts
That bumper is toast. When you remove it, you'll find that the upper flange of the bumper has been cracked and the zip ties are used to help hold it up. Plastic welding will help, but it's really a temporary repair. Removing the front bumper involves removing the five push pins on the top, the two 10mm bolts on the sides (if they're still there) and the 10 mm bolts holding it to the lower splash pan. Consider it a "normal" part of buying a new car and restoring it. Find a local shop to color match it and put a little elbow grease into this DIY project before winter.
Old 06-23-2024, 07:44 AM
jmosh25
jmosh25's Avatar
Yeah the more research I do the more I feel that replacing it would be best.
Old 06-23-2024, 08:00 AM
dkmura
dkmura's Avatar
One other suggestion for a Colorado Z owner is to go with a urethane bumper. Don't try fiberglass or duraflex in our climate as they won't hold up. Also, when you check the bottom of that bumper, it really helps to have the belly pan (or splash shield) intact, as it helps stiffen and reinforce the bumper structure.
Old 06-23-2024, 08:09 AM
jmosh25
jmosh25's Avatar
Awesome I was looking at some KBD urethane ones and they seem like a good option. Definitely makes sense for Colorado too.
jeffreym (06-27-2024)
Old 06-25-2024, 07:42 PM
dkmura
dkmura's Avatar
Where are you in Colorado? You may want to post in the following Colorado Zs thread: Colorado roll call - MY350Z.COM - Nissan 350Z and 370Z Forum Discussion
Old 06-26-2024, 06:02 PM
elftale
elftale's Avatar
oof, those cracks look nasty. good luck with the repair!
jmosh25 (08-11-2024)
Old 08-11-2024, 04:49 AM
ddkaba
ddkaba's Avatar
If I were you, I'd rather replace the bumper. Even if you unmount it, I don't think it will be as strong.
cheap report - click here
Old 08-11-2024, 01:03 PM
jmosh25
jmosh25's Avatar
Yeah, that's what I am planning on doing. I'm working on some other repairs that have taken priority but I plan on getting a new one before winter!
JoeNaps
11-25-2016 09:42 AM
phile
11-09-2007 07:46 AM
vantage350z
07-20-2006 03:41 PM
Quick Reply: Front bumper cracks
