Can anyone identify the purpose of this connector?
Old 07-22-2024, 02:52 PM
johnnym3z
johnnym3z's Avatar
Default Can anyone identify the purpose of this connector?
Hi all, long time lurker, first time poster. I’ve been having issues with my tri-gauges since I got my ‘04 350z roadster and the nav screen has never worked. I took apart the waterfall, disconnected both of the plugs connecting the tri-gauge pod at the top and on the twist of a key, my nav screen came to life!
Through various tests, I’ve figured out that only one of the connectors seems to power and control all the gauges, while the other one does nothing. However, when I plug the “useless” connector in, my nav screen goes dead again.
Please see photos if it helps and let me know if you have any clue what this connector does. Is it worth running with that one unplugged to have the nav screen work or does it perform some important function that I’m not yet aware of?
TIA!
Pointing at the connector that kills my nav screen.
Said connector plugs into here.
Also, do we have any idea what this ribbon does? I figure it’s likely linked to the issue as well given that it connects right next to the plug for the “useless” connector, and it seems to be pretty badly corroded so maybe this is what’s really causing my issue?? I don’t know anymore…
I’ve never posted online for anything before because there’s always been so much existing info out there already but this one has really stumped me :/
Old 07-23-2024, 04:54 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
I'm not sure about the "useless connector" behind the triple gauge cluster. It might plug into something, or it might not. I think manufacturers will install a lot of universal wiring in vehicles and some connections are left unplugged based on different model options (nav, premium audio, etc.).
As far as the ribbon cable, that is very important as it is responsible for climate control. There are many instances of people crimping or damaging that ribbon cable during stereo installs and then their climate controls get messed up like the A/C on full blast and the inability to turn it off. I think a lot of other functions are also routed through that white box.
Old 07-27-2024, 10:00 PM
Someone12132
Someone12132's Avatar
I believe that "useless connector" does connect to the nav screen. It doesn't connect to the screen itself, but it instead connects to the buttons that control the navigation system. I have a '04 350z Roadster as well, and for me, leaving that disconnected prevents the navigation screen from turning on. I'm pretty sure if you leave that disconnected, it won't affect your drivability with the car.
Old 07-30-2024, 04:23 PM
icer5160
icer5160's Avatar
Yes, I'm almost positive that the white harness plug & ribbon cable are related to the NAV system (The ribbon cable Heel is referring to is different). The standard (non-Nav) triple gauge PCB does not have that extra white module/box on the back with the white harness plug socket or ribbon cable. Those must be NAV related items. I believe Someone12132 is correct. But I admit, I haven't looked at the back side of these closely on a pre-2006, let alone one with NAV.
The FSM doesn't help much here, the removal instructions never mention harness connections. Just the core system components (gps ant location, switches, display screen, and control unit).
Leaving the NAV related harnesses disconnected shouldn't impact your triple gauge pod. Can you elaborate on the problems you're having with the triple gauges?
Cheers!
-Icer
Old 08-06-2024, 01:38 AM
PaulBrunet
PaulBrunet's Avatar
Thanks for the info, I also want to know it.
misterclean
02-03-2005 01:34 AM
vova151
03-19-2004 07:19 PM
SalTNutz
12-05-2002 02:14 PM
Quick Reply: Can anyone identify the purpose of this connector?
