ABS Module Issues
Old Today | 12:49 PM
nando64's Avatar
nando64
Exclamation ABS Module Issues
2005 Nissan 350z / Anniversary Edition / Auto Trans / Brembos
ABS, BRAKE, VDC and SLIP light all on my dash. Scanner cannot communicate with abs module.
Proceeded to check basics, found fuse in IPDM Box labeled Brake to be blown- attempted to replace fuse to rescan but fuse immediately and violently blew.
Unplugged all connectors going to abs module and fuse continued to blow.
Okay... so short to ground present in harness leading from IPDM to ABS module, I proceeded to unplug connectors off the IPDM until said fuse no longer received power - (In this case ground). I found the corresponding harness and confirmed fuse no longer blew when harness was unplugged.
I had an oversight and didn't even bother checking online for a wiring diagram before continuing but, I backprobbed said harness and found which wire was grounding out the IPDM, I unhooked that one wire and short to ground was no longer present.
I was lazy and did a continuity test rather than removing cowl and wipers and following the wire physically leading to the ABS module. I found what I thought to believe was the correct wire through a continuity test from harness to harness, (Which I now realize is a flawed way to check, don't chew me out too bad lol), I ran a new wire -- (Again because I didn't want to remove cowl, have to uncharge the ac and remove ac lines and remove brake lines then have to bleed the brakes) -- with the new wire ran and everything hooked back up the short to ground was gone, the fuse no longer blew and the pump runs... great! Right? Well... now the pump runs but runs constantly and stays on even when car is off but ignition on. Still on my idiocy I figured the relay built into the module might've been damaged so I just ordered a new module and threw it in knowing it was unlikely, with the new module in the symptoms remain the same.
I'm now trying to find a wiring diagram on the FSM, but it's honestly, hard to read.
I'm not afraid to admit my rush job was wrong and I understand I didn't do a proper diag before proceeding with attempted repairs.
I'm humbly asking for assistance before proceeding any further, with reading the FSM. It almost appears to me as if the FSM shows a different style ABS module than mine. I have attached a photo of my style abs module...
I appreciate any insight and feel free to chew me out lol.
My style ABS Module
My style ABS Module
calvin.w
May 26, 2021 07:20 AM
Key Mucciante
Dec 1, 2016 01:12 AM
loudrims_inc
Jul 7, 2009 08:00 AM
dreamspeed
Feb 23, 2007 04:11 PM
Voboy
Jun 3, 2006 09:26 PM
