South Central Kansas, Missouri, Kentucky, Oklahoma, Arkansas, Tennessee, Louisiana, Mississippi, Alabama
Little Rock and surrounding areas
Old Feb 10, 2009 | 10:34 PM
  #1701
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
your body shop should be able to figure that out! call the dealership w/you VIN# they should be able to tell you also.
Old Feb 11, 2009 | 06:34 PM
  #1702
luv2bsidewaz's Avatar
luv2bsidewaz
A ? What benefit is it to run different hoses, like the Samco, Mishimoto, etc., hoses in your cars? Better heat dissipation? More rigidity, not so much flex? Just looks? Have seen them and was just wondering the value of them.
Also, FD gears. I've been reading a lot on them and have a question. Is a re-flash absolutely necessary, raising the rev limiter to 7200 rpm, to handle the shorter gears? I think you couldn't go wrong with either the 3.9 or the 4.08. I'm not sure which yet but I am still searching around. The re-flash thing was a concern though.
Old Feb 12, 2009 | 01:49 AM
  #1703
ARMSTRONGARMS
Hoses are for looks mostly, but since they're silicone they will last a long time. IMO i wouldnt waste your money until a replacement is necessary.
As far as FD the 4.08 IMO is just to low of gear and takes away to much of top end speed, and would make traction on the bottom end alot harder. Especially w/o a ugraded LSD. I personally am going/searching for the 3.9.
I've said it before, but i guess i will have to repeat it i would not get a reflash!!!! If you take your car in for maintenance at the dealer and they have to clear codes etc. your flash will be gone. Since we have zero for tuners in the area and driving to dallas,etc would be a PIA for that utecs,haltecs,etc. are out and i would get a Cobb accessport were you can get tunes online, etc.etc. oh and raise your rev
Old Feb 12, 2009 | 01:52 AM
  #1704
ARMSTRONGARMS
Tim or Steve you need this
https://my350z.com/forum/drivetrain/...ded-vb-tq.html
Old Feb 12, 2009 | 04:31 AM
  #1705
Davidb's Avatar
Davidb
If the dealer clears codes it will not reflash your ecu...if they have a update for your specific concern then they will reflash your ecu. If your still under warranty then they will just do it..if your not then they should call and try to sell you a reflash. Or at least that's how it works at the dealerships I have worked at...
Old Feb 12, 2009 | 09:24 AM
  #1706
ARMSTRONGARMS
Hmmm? my bad, i have read to many ill stuff w/relfashes i guess? for the money i would just as soon have equip n my hand say accessport? Ive never read or heard anyone to be happy w/a reflash unluess it was soley for a rev limit change, with the reflash its stuck like that forever or until you pay the same amount for another flash. so its makes more sense to get something like a acessport where you can continue to change as your needs change, plus the fact you can sell it you need to.
Old Feb 12, 2009 | 10:08 AM
  #1707
luv2bsidewaz
Yeah sorry I always say re-flash when I mean re-tune. Lol! I was wondering if it was absolutely necessary to get a re-tune when upgrading FD Gears so that you could raise your rev limiter. I would definitely get an access port if I were doing that. And with the hoses I figured they were something like that. I was just wondering because I see so many for sale and was just wondering if they offered any benefit over longevity/looks.
Old Feb 12, 2009 | 06:49 PM
  #1708
Davidb's Avatar
Davidb
+1...I totally agree with you The only downfall that I can see with the AP is nobody has made decent power gains with it. But more then likely i'll either be going with that or osiris...
And about the FD gears...I to have been looking at this. The 4.08 wouldn't loose any useable top end...you would just have to shift into 6th. Here is what I came up with.
I used the stock tire size on a 06. Here is the stock gearing. (NON REV-UP)
3.538
redline...6700rpms
1st...3.794
2nd...2.324
3rd...1.624
4th...1.271
5th...1.000
6th...0.794
MPH
1st...39
2nd...64
3rd...92
4th...118
5th...150
6th...189
Here is 3.9 FD
1st...35
2nd...58
3rd...83
4th...107
5th...136
6th...171
Here is 4.08 FD
1st...34
2nd...56
3rd...80
4th...102
5th...130
6th...164
Now correct me if i'm wrong on any of the gearing. All I did was google this info. But going from a 3.9 to a 4.08 with our 6 speed tranys isn't going to effect 1st and 2nd as much as it does the rest of the gears. That being said I would still go for the 3.9 just for the fact that it will almost be as low as the 4.08 but it will be better for cruising in 6th.
Old Feb 12, 2009 | 09:47 PM
  #1709
luv2bsidewaz
Wow. You can really see the difference in the 3-6 gears there. I think the 06 rev-up has a little bit better max speed per gear but that's due to the higher rev limiter(i think). But before I get the FD gears I need an lsd. And then I want brakes. And then more stuff.....
Old Feb 12, 2009 | 09:48 PM
  #1710
luv2bsidewaz
Hey guys.... I'm just gonna throw it out there and say...... I wanna go fast.
Old Feb 14, 2009 | 06:05 PM
  #1711
ARMSTRONGARMS
LOL holy crap what a mad house out there! I was like WTF when a friend mentioned it is valentines day, ummm oh yeah.
Old Feb 16, 2009 | 03:17 PM
  #1712
ARMSTRONGARMS
Alright im tired of this **** and im only going to say it once! Everyone better pipe down on here, threads getting out of hand
Old Feb 16, 2009 | 04:27 PM
  #1713
ARMSTRONGARMS
If any of you like animation i strongly suggest watching madagascar 2, that ish was super funny! one of the better movies ive seen in awhile really.
Old Feb 16, 2009 | 05:18 PM
  #1714
luv2bsidewaz
The first Madagascar was funny too but I haven't gotten to see the second one yet. If anyone likes movies like that then go on youtube and look for the upcoming movie called 9. It looks freakin awesome! Wooo!
Old Feb 16, 2009 | 05:29 PM
  #1715
ARMSTRONGARMS
Zach you still need the hood templates?
Old Feb 17, 2009 | 09:38 AM
  #1716
luv2bsidewaz
Na! Thanks though. I found one in the thread of mine you commented on! The hood has been cut already and looks good! I can't wait to get it back. I'll post pics of it asap when I get it back!
Old Feb 17, 2009 | 09:40 AM
  #1717
ARMSTRONGARMS
sweet looking foward to pics, i may have to do this also w/my factory hood.
Old Feb 17, 2009 | 04:52 PM
  #1718
Davidb's Avatar
Davidb
what are y'all talking about? With the hoods?
Old Feb 17, 2009 | 05:22 PM
  #1719
luv2bsidewaz
The RS Concept 350z hood. It looks good. I've seen cell pics of the hood and there are like 1 or 2 little spots to it that I am not happy with but that is just me being WAY ocd perfectionist about it. You have to be right on top of it to notice it at all. Over all I think I am going to like it alot. If not then I'll think of something....
Old Feb 17, 2009 | 11:56 PM
  #1720
ARMSTRONGARMS
You are going to put mesh underneath right?
