CO Drag Times
Old Mar 14, 2007 | 10:25 PM
Redline350Z_CO's Avatar
Redline350Z_CO
Default CO Drag Times
Just wonderin what the members of the Colorado crew are runnin on their drag times on average?
Old Mar 15, 2007 | 05:25 AM
Mudd's Avatar
Mudd
Stock prepared...........about 15.0-15.5. I see you have a few mods, you might be able to squeeze out a 14.8 or 14.9 with the right atmospheric conditions. It will take you some time to get your launch down right and everything, but once you do it a few times you'll be ok.
I'm thinkin you should come run the Friday night ET series with us this summer. Heres a link for some more info. I will guarantee you will have a great time.
http://www.bandimere.com/events/disp...hp?eventID=261
Mudd
Old Mar 15, 2007 | 05:33 AM
hr2burn's Avatar
hr2burn
14.87 Stock
Old Mar 15, 2007 | 10:00 AM
Redline350Z_CO
Nice, that does sound fun. What would you guys say is a good rang in rpm to launch at?
Old Mar 15, 2007 | 10:20 AM
Juztin's Avatar
Juztin
6600 rpms
Old Mar 15, 2007 | 10:36 AM
hr2burn's Avatar
hr2burn
With that stupid "dual" stock clutch, I found much over 3k and your clutch pedal will stick halfway to the floor!!!!
Jman
Old Mar 15, 2007 | 10:41 AM
plumpzz's Avatar
plumpzz
Jman
That happens with older transmissions!. It happened with the transmission that came in my 05. I had it replaced for grinding, and now its much better.
Old Mar 15, 2007 | 12:40 PM
hr2burn's Avatar
hr2burn
ummmmm...no it's the clutch.....
Old Mar 15, 2007 | 03:43 PM
Redline350Z_CO
Old Mar 15, 2007 | 05:15 PM
Abishop's Avatar
Abishop
15.1 is my best time. ill hopefully break into the 14's this season.
Old Mar 15, 2007 | 06:02 PM
hr2burn's Avatar
hr2burn
Maybe if you we're to visit the track more often......say April 25th!!!!
Old Mar 15, 2007 | 06:49 PM
Abishop's Avatar
Abishop
Ha ha, yea i am racing in the Friday night ET series this season are you too Sean?
Old Mar 15, 2007 | 07:22 PM
Mudd's Avatar
Mudd
Much more then 3000 RPM and it feels like the rear end is going to fall out of the car on the track.
Once you go up there for the first time you will find what works for you best and can experiment from there. You have to find what works for you.
Old Mar 16, 2007 | 12:09 PM
myspivey's Avatar
myspivey
What PSI do yall run in your tires and what widths do you have? Im curious as to what you do to prep the car for your optimal launch.
Old Mar 16, 2007 | 12:19 PM
Redline350Z_CO
I was told recently 25psi was good to run at
Old Mar 16, 2007 | 02:50 PM
Mudd's Avatar
Mudd
I am usually at 25-30psi. I run Toyo T1-R tires in the stock sizes on 18's.
That set up worked well in the past but something tells me I may be going to a wider tire with the F/I set up. I will wait and see how she behaves on the track first before I make that investment
Old Mar 16, 2007 | 02:55 PM
myspivey's Avatar
myspivey
Hey, i have 275's on the back so i got plenty of tire.... 25 PSI huh? Allow for more give to keep more rubber down?
Old Mar 16, 2007 | 03:05 PM
Mudd's Avatar
Mudd
Yeah a little, ya know with these stiff sidewall tires they don't give much IMO. So dropping the PSI a little helps some. Obviously the best would be to get some drag radiels or something with a less stiffer sidewall.
Old Mar 16, 2007 | 04:01 PM
hr2burn's Avatar
hr2burn
I drop my rears (stock) to 27lbs...it help's
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
