Need help installing Tein Flex with EDFC
Looking to see if some can help me to install the flex system with EDFC, Let me know if anyone knows how to do it or what will you charge?
I'm curious to see how hard it is to install just the EDFC. Tein gave me their Flex setup after some testing they did, and now I want to add on the controller.
Any step by step instructions, I have a member sending me info for a company that will install between 300-400 for installion of the hole system. i will post once received.
Send a PM to protocav. He did mine and many many others' coilover installations on both 350Z and G35s for half the price of any shop I got quotes from. I wouldn't go anyplace else for an install. He is down in SD, but it's honestly worth the drive on a job like this, to get it done quickly and with quality. Best of all you save some $$$.
Jim
Jim
I'm guessing the install of just the EDFC on my Flex is about the same as installing the coilovers and EDFC at the same time since you gotta remove them to get the EDFC under there. huh?
The edfc cost more cause of the wiring, I think you have to take apart the interior. So thats why its a little more expensive than just installing the suspension.
Yes, the EDFC costs a little bit more than installing just the coilvers them selves.
And yes, paying to have the EDFC installed later will cost more than doing it at the same time as the coilovers.
I've done about a dozen of these installs, there's no real step by step instructions. I guess someone could make one, but it would be really long, theres so many steps, lol.
Protocav did my coilovers for steal ... but I was doing A-Arms, toe bolts, camber arms, a plenum, intake, and some other misc. goodies too.
His price list for coilovers w/ edfc says $200. He's pretty non-negotiable on price unless you got tons of other work too ... but still ... at $200 I was racing there to get it done!
Good luck,
Jim
Good luck,
Jim
^ Definately. $200 for installation of coilovers and EDFC is a steal. I cannot do it for that low. The installation will take nearly an entire work day. I have too many other cars I would rather do than put in that much work for only $200.
Sure. Send a PM to memeber Protocav, tell him Jim recommended you. I know he is busy lately, but he mangaged to squeeze me in when I was in a hurry to return my car back to stock to trade it in. He worked overnight for me, literally.
Jim
Jim
I just installed, ! problem came out, I guess my rim was hitting the strut. I think it was dropped to low. Can some let me know whats the problem, I have 20 TSW thruxtons with 285/30/20, Are my rims and tires to wide?
You probably have too much negative camber in the rear. Get an alignment and get the rear camber closer to stock and you will gain some clearance between the wheel and the damper.
I had to raise the 1/2 inch, It was to low, Still need to install the EDFC unit and wires. I should of gone where i was recommended. Now i have to pay someone to do the EDFC and wires.
... jk Glad to see you got the problem worked out. Good luck with the EDFC .. shops will rape you on that one.
