Need help with UR pulley kit - Will Pay $
Old Jul 8, 2007 | 11:43 PM
  #41
FastZ33's Avatar
FastZ33
idk man i tried somthign liek that and it didnt work. all the pulleys were spinning
Old Jul 10, 2007 | 08:11 PM
  #42
918 Z's Avatar
918 Z
it should lock, thats weird. brake firmly pressed down and car in 6th gear the pulley should lock, it will have a lil play but otherwise it should lock
Old Jul 10, 2007 | 10:52 PM
  #43
FastZ33's Avatar
FastZ33
lol u wanna come over and do it for me
Old Jul 11, 2007 | 12:06 AM
  #44
918 Z's Avatar
918 Z
lol, maybe you could bring it by my place, let me just get some free time
Old Jul 12, 2007 | 12:46 AM
  #45
FastZ33's Avatar
FastZ33
when lol
Old Jul 16, 2007 | 07:38 AM
  #46
lbz's Avatar
lbz
Well, I FINALLY got it done! The main bolt was a bit of a bish. I had the breaker bar with a 2 ft pipe over it and had gone pretty much from one side all the way over to the other side and it would not break loose.
I decided to take a break and then went back and managed to fit the socket on one more point to the right and when I came across again, about 3/4 of the way, it popped.
Am going to try and put together a procedure with the best sequence of events (with pics), based on this experience, to save time and effort for anyone else
Was a bit surprised but glad when no noise from any of the belts after I started it up. Learned some more good stuff with this mod, especially about planning ahead.
Old Jul 16, 2007 | 08:01 AM
  #47
Cux350z's Avatar
Cux350z
hatersgonnahate
did you use the transmission inspection plate procedure?
Old Jul 16, 2007 | 10:07 AM
  #48
918 Z's Avatar
918 Z
mike finally got his off too. i sent him over to my brothers autoshop and they broke it loose. it was just tightened on reallly bad. note: to those who install aftermarket pulleys, only tighten them down to the specified torque using a torque wrench. using any other kind of tool will cause u pain later on
Old Jul 16, 2007 | 11:36 AM
  #49
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Actually - many aftermarket pulleys do not come with TQ specs - rather than degree specs - like the UR pulleys. The factory pulley has TQ specs..
Rick
Old Jul 16, 2007 | 04:27 PM
  #50
lbz's Avatar
lbz
I didn't use the inspection plate method though I began to consider it when the first big try did not work. I found the plate but after crawling out from under I figure to give it another go and then great success!
UR came with both a torque spec, as a first step, and then the degree spec.
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
