need Suspension help
Old Aug 12, 2007 | 09:27 PM
g35kid18's Avatar
g35kid18
Default need Suspension help
I recently blew i tire on my way to work and i really think it F my suspension. First i thought it was that i went with tires to big because it felt like it was rubbing but i know that is not the case anymore because even going straight my tires feel like they are floating. I need to fix this but i dont know what the problem could be and would like a someone with more experience to tell me what i need to do to fix it. Is there a shop i could take it to, to find out what the problem may be? thanks
Old Aug 13, 2007 | 08:53 AM
MustGoFastR's Avatar
MustGoFastR
I'd just take it to the dealer for an alignment and talk to the tech that dies it and tell him what happened so he can keep a look out for any damaged components.
Did you have more than one tire replaced? If not, the diff. between the older and new tire could be the cause of what you are feeling. Also new tires tend to feel squirly for a while until they are broken in, so it may be nothing.
Old Aug 13, 2007 | 11:28 AM
onedirtyz's Avatar
onedirtyz
my car is dirty
take it to west covina nissan. make sure to talk to frank or tim.
Old Aug 13, 2007 | 07:01 PM
g35kid18's Avatar
g35kid18
ya that is what im going to do west covina is close by...do you have to make appointments for an alignment over there??.....
Ya and i did change both tires
Old Aug 13, 2007 | 07:22 PM
MustGoFastR
If the car isn't pulling to one side and you can't visibly see anything that looks noticably off with the camber of the wheels, it may just be that the tires need to break in. If you have some miles on the car, it wouldn't hurt to get it aligned, though, and checked out, just to be on the safe side.
Old Aug 13, 2007 | 09:04 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
i'd call and talk to tim about an appt, they're pretty accomodating either way.
good luck.
oh yeah... 626 732 1000 x 6343 for tim
Old Aug 13, 2007 | 09:15 PM
wynd d z33's Avatar
wynd d z33
is your car on coilovers or lowered if so you may have camber issues but if its stock you may want to see if they rebalanced your tires before they mounted the new ones you should do that every time you add tires and you should get an alignment anyways too
Old Aug 14, 2007 | 12:12 AM
g35kid18's Avatar
g35kid18
ya its been awhile since the last alignment. The last time is when i put my springs on and that was at least 2 years ago so i hope that sloves the problem thanks guys!
thanks for the # i will give him a call
Old Aug 14, 2007 | 06:34 AM
Jeff@WestCovinaNissan's Avatar
Stop by the parts counter and say hi while you're here!!!
Old Aug 14, 2007 | 07:18 PM
g35kid18's Avatar
g35kid18
ya i will im going to need the spc camber kit do you guys have that there?
Old Aug 14, 2007 | 07:25 PM
Vertex350's Avatar
Vertex350
Yes, I'm sure they do.
Old Aug 16, 2007 | 12:05 AM
g35kid18's Avatar
g35kid18
jeff how much for the spc camber kit for the rear and how much for the install with an alignment?
Old Aug 16, 2007 | 08:03 AM
Justin@WestCovinaNissan's Avatar
The SPC camber arm kit is $218.00 + tax
This includes:
-(2) camber arms
-(2) eccentric bolts for toe correction
Installation would be best quoted by Tim and you can call him direct here.
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
