Need Help, what can cause this?
Old Nov 25, 2008 | 01:57 AM
Cannysage's Avatar
Cannysage
what is your batter voltage at?
Old Nov 25, 2008 | 02:17 AM
Myfirst06350Z's Avatar
Myfirst06350Z
Its def not a battery issue. It's either vaccum or sensor.
Old Nov 25, 2008 | 06:45 AM
hersilverbullet's Avatar
hersilverbullet
Battery is two months old.
Old Nov 25, 2008 | 08:35 AM
Scope350's Avatar
Scope350
well get some sensor cleaner and clean out the connectors and check them to make sure they all look ok. The main problem with this is that it could be a number of things. If cleaning the connectors dont work, then replacing the throttle body itself seems to be the next step. I just looked through the factory service manual. But before you go out an buy one, i would again see if you can find one from a friend or something and see if that solves the problem
Old Nov 25, 2008 | 08:46 AM
hersilverbullet
Thanks Scope I am trying to do the less costly steps first and then moving towards replacing the TB, but that will be my last resort.
Old Nov 25, 2008 | 11:04 AM
Scope350's Avatar
Scope350
no problem. i'll do some more research into the problem and see what else i can dig up. Good luck though, keep us posted on the progress. Anything else i find out, i'll post on here.
Old Nov 25, 2008 | 11:09 AM
RedBullRR's Avatar
RedBullRR
Check and cleam MAF Sensor and TB Sensor.
Old Nov 25, 2008 | 11:55 AM
hersilverbullet
Where is the TB Sensor? I know its on the TB but where and how do you clean it? I have seen the video on cleaning the TB on a G35, which seems to be the same as for a Z.
Old Nov 25, 2008 | 01:29 PM
Scope350's Avatar
Scope350
yep, its the same. not different at all. VQ is a VQ. So ya. Give that a go and clear the codes cause you already know what they are and see if it throws the same code again.
Old Nov 26, 2008 | 05:21 PM
hersilverbullet
Update, just wanted to give a thanks to Brian. He came back to diagnose the car, he and his cousin changed the plugs and she wouldn't start. We decided to change the TB, we were fortunate enough we found one used locally. He installed it, I go to turn on the car and nothing, before I get out Brian says try it again......she starts up without a hitch just a big puff of smoke from the mufflers due to the gas in the engine. Test drove her and she runs like a champ. Thanks once again to Brian for taking time out of his day to help a fellow Z brother out.
Old Nov 26, 2008 | 06:37 PM
Scope350's Avatar
Scope350
glad to hear she started. Congrats.
Old Nov 26, 2008 | 09:35 PM
Myfirst06350Z
No prob. I had fun working on it. Just glad shes up and running again.
Old Nov 26, 2008 | 10:33 PM
hersilverbullet
Thanks guy, Brian did all the work, lol. I am just glad he was able to get her back up and running.
Old Nov 27, 2008 | 12:16 AM
350z006's Avatar
350z006
Congrats...
Noob question....what's a TB?
**Forget it...figured out it was the throttle body**
Didn't know the throttle body had a sensor...
Old Nov 27, 2008 | 07:10 AM
hersilverbullet
I didn't either.
Old Nov 29, 2008 | 07:20 PM
Scope350's Avatar
Scope350
its all electroic so ya it has a sensor for throttle position and such. Cars get more hi tech all the time
