more questions about utec...
Old Apr 3, 2006 | 07:43 PM
phile's Avatar
phile
Originally Posted by audiblemayhem
the manual tells you about everything it does... but it doesnt explain in detail everything it does.
Probably similar to a motherboard manual. That sucks
Old Apr 3, 2006 | 07:47 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
www.turboxs.com click on software and then 350z and you can download the manual...
Old Apr 4, 2006 | 02:52 AM
Bahraini350Z's Avatar
Bahraini350Z
What mods are you running? Did you get it dynoed?
Will the UTEC remove the speed limiter?
If I buy it, will I get a base map designed for my mods?(including cams)
Thanks anyways
Old Apr 4, 2006 | 03:28 AM
Audible Mayhem
My350z
i have a KnN, pulleys, skunk2 spacer, JIC y pipe, and test pipes. the UTEC will come with a base map to give you an idea what the figures will look like BUT they will probably be way way off what you need. i have been tuning my car for a week now to fine tune it and i think i have done a pretty good job. i dynoed my car right when i put the utec in with that horrible base map and only picked up 5 hp with it. horrible only becuase it is way off in my car. i am getting my tuner wb ( a must for self tuning) this friday, i have battle of the imports sunday and test and tune friday so i will get to see what i have done with my car.
i would highly recommend the utec + tuner wb if anyone is wanting to figure out their cars and be able to compensate for any changes needed....
the utec can raise the rev limiter but i dont think it does anything with the speed limiter, you dont need to be driving that fast anyways
oh yeah i have some nitrous too!!!
Old Apr 4, 2006 | 03:49 AM
gringott's Avatar
gringott
I think the speed limiter is removed automatically for the 2003 model, could not get a straight answer, but I was able to take mine to 160. It is not listed as a parameter in the UTEC menu, however.
Old Apr 5, 2006 | 06:07 AM
King Tut's Avatar
King Tut
can you run open loop fueling naturally aspirated???
if so that is what i will be doing tomorrow. i would love to bypass the stock ECU...
i guess what i am wondering, can you run speed density NA???
Yes, but you need to purchase the $115 Turbo XS MAP sensor and hook it up to your UTEC. You can ONLY run speed density with the Turbo XS MAP sensor.
Old Apr 5, 2006 | 07:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You do not need a MAP sensor to tune in open loop fueling. Open Loop Fueling mode can be run with either a factory MAF sensor, or a MAP sensor (for FI applications). You can still set the injector pulse widths with an NA car, and the basic UTEC.
Old Apr 5, 2006 | 08:25 AM
King Tut's Avatar
King Tut
I read it again and you are correct in MAF mode with open loop fueling it takes the adjusted MAF voltage and then modifies the injector pulse widths. I was stating that to run speed density mode he would need a MAP sensor. They are two different modes one bases load off of the TPS sensor and one bases load off of the MAP sensor. You can run either in open loop fueling mode. Either will work in an all motor application.
Old Apr 5, 2006 | 08:47 AM
Sharif@Forged
Forged Performance
Actually, speed density mode should never be used on an NA car. Otherwise, you will have no resolution beyond 0psi. MAF is the way to go.
Old Apr 5, 2006 | 10:26 AM
King Tut's Avatar
King Tut
That makes no sense. Why would you want resolution beyond 0 psi? An all motor car can't reach past 0 psi. There should be a way to setup your load columns to represent -15 in/hg to 0 in/hg which will cover partial and full throttle so you can use speed density. Then you would have each column be around 1.5 in/hg difference which would give great fine tuning abilities. Not sure if thats possible, but it should be.
Old Apr 5, 2006 | 10:51 AM
350Zenophile's Avatar
350Zenophile
Three questions:
1. Do you need the WB sensor to tune in MAF mode?
2. Don't the 04+ have WB sensors?
3. When you tune an NA car in MAF mode, do you still have control over timing or is it just fuel control?
Old Apr 5, 2006 | 12:14 PM
King Tut's Avatar
King Tut
1. I'm not sure how you plan to tune without having a wideband to know what your air fuel ratio is as that is the main thing used in tuning the fuel tables, but technically no you don't need one.
2. They say the 04.5+ have WB O2 sensors.
3. Yes you still have control over timing in MAF mode.
Old Apr 5, 2006 | 03:43 PM
Audible Mayhem
My350z
well having a vacuum gauge in my car and watching the vacuum all the time. i realized that it flucuates so much that you couldnt tune it to the vacuum with the MAP sensor. even if you tuned it to vacuum. now yes this whole time i have been messing with the utec, i am in open loop fueling using the maf pulldown
the question is?? does the utec use the figures you put in say -0.8% now does the utec use the MAF voltage, minus .8 % and send the injectors its own configurated pulse widths OR.... take the MAF voltage and correct that and send it to the ECU to "edit" what the computer does for the injector pulse widths??
thanks guys...
Old Apr 5, 2006 | 04:55 PM
ACEMAN's Avatar
ACEMAN
Master
Thought i would post a bit of my log file. Its a third gear pull. Let me know what you guys think. Im still using the timing map that came with the UTEC. I also had the AAM reflash before i installed the UTEC.
Code:
5081 -17.8 4.23 102  80    00   14.31 +25.1   60.3 +20.2  -7.0     4.15  14.37
 5073 -17.8 4.37 102  80    00   13.89 +26.0   58.9 +20.1  -6.9     4.03  13.59
 5096 -17.8 4.49 103  80    00   14.58 +25.9   62.0 +20.4  -7.0     3.84  13.28
 5136 -17.8 4.31 102  80    00   14.47 +24.1   63.0 +20.6  -7.1     4.07  13.14
 5224 -17.8 4.25 102  80    00   14.53 +23.9   63.0 +20.7  -7.3     4.13  13.12
 5257 -17.8 4.45 102  80    00   14.70 +24.1   64.4 +21.0  -7.3     3.82  13.12
 5274 -17.8 4.37 103  80    00   14.79 +24.0   64.1 +21.0  -7.5     4.09  13.06
 5341 -17.8 4.29 103  80    00   14.85 +24.2   65.8 +21.0  -7.5     4.11  13.06
 5376 -17.6 4.45 102  80    00   14.37 +24.1   64.5 +21.0  -7.6     3.92  13.02
 5411 -17.8 4.31 103  80    00   14.65 +24.9   66.2 +21.0  -7.6     4.13  13.06
 5464 -17.8 4.52 103  80    00   14.77 +24.9   67.4 +21.0  -7.7     3.92  13.12
 5500 -17.6 4.27 102  80    00   14.49 +25.0   66.4 +21.0  -7.8     4.15  13.12
 5537 -17.8 4.52 103  80    00   14.63 +25.0   66.7 +21.1  -7.8     4.15  13.12
 5611 -17.6 4.54 103  90    00   14.49 +24.9   67.7 +21.2  -7.8     3.80  13.09
 5611 -17.6 4.29 103  90    00   14.79 +24.9   69.8 +21.2  -7.9     4.21  13.12
 5678 -17.6 4.62 103  80    00   14.93 +25.8   70.5 +21.4  -7.9     4.23  13.09
 5688 -17.6 4.56 103  90    00   14.85 +25.9   70.4 +21.4  -7.9     4.03  13.06
 5757 -17.6 4.35 103  90    00   15.32 +25.9   73.8 +21.5  -8.0     4.13  13.06
 5757 -17.6 4.21 102  90    00   15.22 +25.7   73.8 +21.5  -8.0     4.27  13.02
 5847 -17.6 4.56 102  80    00   15.36 +25.8   74.5 +21.7  -8.0     4.19  13.02
 5868 -17.6 4.66 102  90    00   15.43 +26.0   78.0 +21.8  -8.1     4.17  12.99
 5963 -17.6 4.62 101  90    00   15.57 +26.8   76.7 +21.8  -8.1     4.03  12.99
 5931 -17.6 4.58 101  90    00   15.47 +25.9   77.0 +21.9  -8.1     4.07  13.02
 5984 -17.8 4.64 101  90    00   15.27 +26.8   77.0 +22.0  -8.2     4.11  13.03
 6027 -17.6 4.64 100  90    00   15.50 +26.8   78.3 +22.0  -8.2     4.07  13.12
 6049 -17.8 4.62 100  90    00   15.11 +26.9   76.9 +21.8  -8.2     4.09  13.12
 6161 -17.6 4.64 101  90    00   15.02 +26.8   76.7 +21.8  -8.3     4.09  13.17
 6150 -17.6 4.64 102  90    00   14.69 +26.9   75.9 +21.7  -8.3     4.23  13.28
 6184 -17.6 4.80 102  90    00   14.63 +26.9   76.7 +21.6  -8.3     4.23  13.39
 6242 -17.6 4.60 102  90    00   14.49 +26.9   75.7 +21.5  -8.3     4.31  13.53
 6253 -17.6 4.54 102  90    00   14.42 +26.9   75.3 +21.6  -8.4     4.27  13.65
 6313 -17.6 4.52 102  90    00   14.37 +27.8   75.0 +21.9  -8.2     4.19  13.75
 6385 -17.6 4.68 102  90    00   14.26 +27.8   75.7 +22.0  -8.0     4.17  13.84
 6447 -17.6 4.76 103  90    00   13.89 +27.7   76.7 +22.1  -8.0     4.31  13.92
 6447 -17.6 4.60 102  90    00   13.67 +27.8   73.6 +22.4  -7.8     4.09  14.05
 6422 -17.6 4.68 103  90    00   14.12 +27.6   75.7 +22.3  -7.8     4.13  14.05
 6510 -17.6 4.74 102  90    00   13.96 +27.7   75.3 +22.5  -7.8     4.37  14.11
 6535 -17.6 4.54 102  90    00   14.08 +27.8   76.4 +22.8  -7.6     4.27  14.15
 6600 -17.6 4.76 103  90    00   14.21 +27.7   77.6 +22.8  -7.3     4.39  14.08
 6587 -17.6 4.64 102  90    00   14.56 +27.5   80.3 +23.0  -7.2     4.15  14.05
 6626 -17.6 4.78 102  90    00   14.45 +27.6   80.2 +23.2  -7.1     4.37  13.95
 6653 -17.6 4.64 102  90    00   14.63 +27.8   81.5 +23.3  -7.1     4.19  13.84
 6761 -17.6 4.78 102  90    00   14.70 +27.7   82.2 +23.6  -6.8     4.47  13.78
 6747 -17.6 4.56 103  90    00   14.67 +27.6   83.4 +23.5  -6.8     4.29  13.72
 6775 -17.6 4.72 103  90    00   14.28 +27.8   81.0 +23.6  -6.5     4.50  13.65
 6872 -17.6 4.76 102  90    00   14.61 +27.7   84.3 +23.9  -6.5     4.47  13.65
 6872 -17.6 4.64 102  90    00   14.79 +27.6   84.8 +24.0  -6.4     4.37  13.68
 6858 -17.6 4.74 102  90    00   14.70 +27.7   84.3 +24.1  -6.2     4.52  13.65
 6901 -17.6 4.82 103  90    00   14.81 +28.7   85.0 +24.4  -6.2     4.50  13.65
 6958 -17.6 4.60  99  90    00   14.76 +28.5   87.0 +24.5  -6.1     4.31  13.65
 7002 -17.8 3.88   0  90    00    4.13 +29.3   24.2 ECU.   -6.0     2.33  13.81
Old Apr 5, 2006 | 04:58 PM
Audible Mayhem
My350z
as i pmed you, look at how far your timing is off.... it is really retarded almost 5 degrees in spots. we need to get this adjusted and open up lots more power. i lost 25 hp on the dyno with 4 degrees taken off
Old Apr 5, 2006 | 05:36 PM
ACEMAN's Avatar
ACEMAN
Master
Here is a run in third gear with everything under timing set to ECU.
Code:
3223 -17.8 3.62 102  70    00   12.32 +25.3   32.9 ECU.   +3.0     3.70  14.33
 3267 -17.8 3.74 103  70    00   12.70 +25.3   34.7 ECU.   +2.9     3.72  13.95
 3300 -17.8 3.58 103  70    00   13.23 +25.3   36.6 ECU.   +2.8     3.76  13.53
 3363 -17.8 3.64 103  70    00   12.98 +25.3   36.5 ECU.   +2.6     3.70  13.33
 3411 -17.8 3.66 103  70    00   13.05 +25.2   37.1 ECU.   +2.5     3.76  12.89
 3461 -17.8 3.76 103  70    00   13.69 +25.3   39.5 ECU.   +2.2     3.84  12.56
 3508 -17.8 3.88 103  70    00   12.43 +25.2   39.6 ECU.   +1.8     3.96  12.37
 3568 -17.8 3.86 103  70    00   13.87 +25.3   41.2 ECU.   +1.5     3.94  12.34
 3611 -17.8 3.86 104  70    00   13.96 +25.2   42.1 ECU.   +0.6     3.92  12.42
 3658 -17.8 3.90 103  70    00   13.26 +25.3   42.5 ECU.   +0.0     3.98  12.56
 3736 -17.8 4.00 103  70    00   13.30 +25.2   41.1 ECU.   -0.3     3.90  12.78
 3753 -17.8 3.92 103  80    00   12.73 +25.1   41.4 ECU.   -1.2     3.98  12.93
 3805 -17.8 3.82 103  80    00   13.28 +25.3   42.5 ECU.   -1.3     3.92  13.17
 3871 -17.8 3.86 102  80    00   13.80 +25.1   44.7 ECU.   -1.5     3.92  13.39
 3954 -17.8 3.78 103  80    00   14.67 +25.2   48.2 ECU.   -1.8     3.96  13.50
 3996 -17.8 4.13 103  70    00   14.76 +25.2   48.9 ECU.   -1.9     3.94  13.53
 4161 -17.8 3.96 103  80    00   13.57 +24.1   46.8 ECU.   -3.0     3.84  13.47
 4030 -17.8 3.82 103  80    00   14.29 +24.1   48.5 ECU.   -2.8     3.88  13.33
 4187 -17.8 4.11 103  80    00   13.39 +24.2   46.1 ECU.   -3.2     3.86  13.23
 4171 -17.8 4.01 103  80    00   13.26 +24.1   46.6 ECU.   -3.6     3.94  13.14
 4219 -17.8 4.15 102  80    00   12.94 +24.1   45.6 ECU.   -3.6     3.92  13.20
 4340 -17.8 4.03 103  80    00   12.87 +24.1   46.4 ECU.   -4.0     3.92  13.25
 4334 -17.8 4.25 103  80    00   12.77 +24.1   46.6 ECU.   -4.0     3.96  13.45
 4420 -17.8 4.13 103  80    00   13.07 +24.1   46.0 ECU.   -4.0     4.05  13.53
 4748 -17.8 4.05 102  80    00   12.61 +23.0   47.2 ECU.   -4.0     3.98  13.53
 4492 -17.8 4.33 103  80    00   12.68 +24.1   47.7 ECU.   -4.0     3.86  13.47
 4535 -17.8 4.37 103  80    00   13.07 +24.2   49.9 ECU.   -4.8     4.09  13.36
 4604 -17.8 4.17 103  80    00   13.28 +23.9   49.7 ECU.   -5.0     4.09  13.28
 4688 -17.8 4.01 103  80    00   13.53 +25.0   52.1 ECU.   -5.4     4.07  13.14
 4728 -17.8 4.13 103  80    00   13.25 +26.1   52.3 ECU.   -5.8     3.88  13.12
 4768 -17.8 4.29 103  80    00   13.80 +26.1   55.5 ECU.   -6.1     3.92  13.12
 4796 -17.6 4.33 102  80    00   13.94 +26.1   56.4 ECU.   -6.2     3.92  13.17
 4923 -17.8 4.27 103  80    00   13.90 +26.0   56.5 ECU.   -6.4     3.92  13.23
 4894 -17.8 4.21 103  80    00   13.90 +27.0   57.3 ECU.   -6.6     4.00  13.17
 5035 -17.8 4.07 103  80    00   13.97 +26.1   62.3 ECU.   -6.9     4.11  13.06
 4997 -17.8 4.21 102  80    00   14.13 +25.0   58.9 ECU.   -6.7     4.15  12.96
 5120 -17.8 4.39 103  80    00   15.13 +25.1   64.3 ECU.   -6.9     4.05  12.93
 5112 -17.6 4.49 103  80    00   15.20 +23.9   65.2 ECU.   -7.1     3.86  12.93
 5192 -17.8 4.29 102  80    00   14.65 +24.0   65.0 ECU.   -7.2     4.09  12.92
 5257 -17.8 4.25 103  80    00   14.90 +23.9   65.4 ECU.   -7.3     4.09  12.93
 5257 -17.8 4.50 103  80    00   15.00 +23.9   66.2 ECU.   -7.4     3.92  12.92
 5333 -17.6 4.17 102  80    00   14.93 +23.8   66.1 ECU.   -7.4     4.11  12.96
 5420 -17.8 4.49 103  80    00   14.72 +23.9   66.4 ECU.   -7.6     3.94  13.02
 5464 -17.8 4.37 103  80    00   14.83 +25.0   67.2 ECU.   -7.7     4.15  12.99
 5491 -17.6 4.52 103  80    00   14.93 +25.0   68.4 ECU.   -7.7     3.84  12.99
 5546 -17.6 4.17 102  80    00   14.61 +24.8   68.4 ECU.   -7.8     4.21  12.99
 5611 -17.8 4.58 103  80    00   14.74 +24.8   68.9 ECU.   -7.8     4.01  13.02
 5630 -17.8 4.29 102  80    00   15.29 +24.9   72.0 ECU.   -7.9     4.13  13.06
 5688 -17.6 4.37 103  80    00   15.15 +24.9   72.9 ECU.   -7.9     4.19  13.06
 5727 -17.6 4.66 103  90    00   15.47 +25.9   73.8 ECU.   -7.9     4.03  13.06
 5787 -17.8 4.62 103  90    00   15.52 +24.9   74.5 ECU.   -8.0     4.05  13.03
 5868 -17.6 4.39 103  90    00   15.77 +26.0   76.5 ECU.   -8.0     4.13  13.06
 5910 -17.6 4.47 102  90    00   15.66 +25.9   76.8 ECU.   -8.0     4.33  13.06
 5868 -17.6 4.31 103  90    00   15.77 +26.0   78.4 ECU.   -8.1     4.29  13.03
 5995 -17.6 4.50 102  90    00   15.66 +25.8   77.0 ECU.   -8.1     4.31  13.03
 6027 -17.6 4.58 103  80    00   15.36 +26.9   77.8 ECU.   -8.1     4.29  13.03
 6093 -17.6 4.60 103  90    00   15.13 +26.9   78.2 ECU.   -8.2     4.29  13.09
 6105 -17.6 4.47 102  90    00   15.24 +26.9   77.7 ECU.   -8.1     4.33  13.20
 6207 -17.6 4.43 103  90    00   14.69 +26.8   75.7 ECU.   -8.1     4.39  13.31
 6195 -17.6 4.54 102  90    00   14.72 +26.7   76.3 ECU.   -8.1     4.15  13.47
 6265 -17.6 4.49 103  90    00   14.93 +26.7   78.8 ECU.   -8.0     4.21  13.65
 6325 -17.6 4.68 102  90    00   14.60 +26.9   76.9 ECU.   -7.8     4.15  13.72
 6349 -17.6 4.84 102  90    00   14.53 +26.8   74.8 ECU.   -7.8     4.37  13.84
 6435 -17.6 4.47 103  90    00   14.35 +27.9   76.7 ECU.   -7.7     4.33  13.92
 6435 -17.6 4.56 103  90    00   14.51 +27.7   78.5 ECU.   -7.6     4.19  13.95
 6510 -17.6 4.74 103  90    00   14.19 +26.7   78.6 ECU.   -7.4     4.37  14.00
 6523 -17.6 4.56 102  90    00   14.31 +27.8   77.8 ECU.   -7.3     4.25  13.97
 6587 -17.6 4.72 103  90    00   14.44 +27.9   80.1 ECU.   -6.9     4.29  13.92
 6587 -17.6 4.58 103  90    00   14.69 +27.8   81.2 ECU.   -6.7     4.43  13.78
 6613 -17.6 4.78 103  90    00   14.67 +27.6   81.5 ECU.   -6.6     4.25  13.72
 6747 -17.6 4.54 103  90    00   14.97 +27.8   83.9 ECU.   -6.5     4.39  13.65
 6720 -17.6 4.74 102  90    00   14.92 +27.7   83.6 ECU.   -6.4     4.47  13.56
 6775 -17.6 4.68 102  90    00   14.72 +27.6   82.8 ECU.   -6.2     4.29  13.50
 6830 -17.6 4.88 102  90    00   14.83 +27.7   83.8 ECU.   -6.1     4.54  13.47
 6816 -17.6 4.82 102  90    00   15.18 +27.6   85.1 ECU.   -6.0     4.43  13.47
 6887 -17.6 4.70 102  90    00   15.13 +27.5   86.5 ECU.   -5.8     4.43  13.53
 6915 -17.6 4.78 103  90    00   14.99 +27.6   87.0 ECU.   -5.6     4.52  13.53
 6988 -17.6 4.84 103  90    00   15.15 +27.5   90.1 ECU.   -5.6     4.56  13.47
 7047 -17.6 4.66 103  90    00   14.83 +28.7   87.8 ECU.   -5.5     4.47  13.59
Old Apr 5, 2006 | 05:51 PM
Audible Mayhem
My350z
did it pull better like that with the stock timing, also i know you are just now starting to tune it, but your AFR from 3300 to 3800 goes from 12.3 to 13.3 hehehe
Old Apr 5, 2006 | 06:03 PM
  #38
ACEMAN's Avatar
ACEMAN
Master
Felt like it did pull alittle harder. And your right, i do need to do some more tuning. Its a process getting everything just right
Later
Aceman
Old Apr 5, 2006 | 06:11 PM
  #39
Audible Mayhem
My350z
cant wait till i pick up my tuner wb on friday, i am going to drive 500 miles logging stuff.....
if you get some time do some nice 3rd gear datalog runs with the same setup that you showed on your latest post. then right down the stock timing across the rpms every 250 for at least 5 runs... then average them out and type those figures in...... then go datalog more and compare them on the datalog sheet and edit where needed.... then advance it a couple degrees and see how she feels!! good luck
Old Apr 5, 2006 | 06:15 PM
  #40
Julian@MRC's Avatar
Julian@MRC
Open loop fueling can be setup as with MAF based, or MAP based...you pick. So yes, you can run open loop fueling mode on an NA car, as long as you select "MAF" for the load indicator. Just a word of caution. When you switch to open loop fueling mode, the ENTIRE fuel map needs to be populated with something, or else the car wont run. It's a time consuming process, the first time around, but once its done, the level of control is amazing.
What he can do, is do a DATA log on the closed loop and see where his injector pulse widths are and fill them in accordingly on the open loop map.It will be VERY time consuming and frustrating until you get a working map and road tune out all the bugs..
What his problem may have been is sometimes if the wire harness is not seated real good, the utec will do some weird things..
Also turn down the knock feedback sensitivity a bit, sometimes it reads engine noise as knock. The car I just tuned today Was real lean when it cam in, like 14.6 and lost tons of power with its breathing mods, but we were able to get over 20whp back in by going to 13.5 A/F until about 5700 then going into the 12.5 range and bumping a little timing back in in the middle..Here is a dyno Graph.
