Uni CHip Questions...
Old May 15, 2006 | 09:44 PM
Mr.Smallville's Avatar
Mr.Smallville
Red face Uni CHip Questions...
I just bought my chip and had a couple questions...How far can i red line it to???I know i could pass the red line but not sure at what rpm to set it to. I got an 03' Touring model with an Injen cold air intake and the Injen Super SES Exhaust.What rpm should i set it to???
Old May 15, 2006 | 10:29 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'm not telling you what you SHOULD set it to, but I know the Technosquare reflash sets the RPM to 7100.
Old May 16, 2006 | 08:10 AM
Mr.Smallville
well i should have said what rpm setting is better recommended.Im not that familier with all the UNi Chip has to offer but i know i can raise the rev limeter.I also know your not supposed to shift in the red but i guess i can now but not that sure where i should set it to.
Old May 16, 2006 | 08:15 AM
dirtroad's Avatar
dirtroad
unless this is a feature of the new unichip, the older ones (that go with APS kits) don't have any sort of feature that raises the rev limiter.
if you can reset it, then 7100 is a good number.
Old May 16, 2006 | 08:27 AM
MIAPLAYA's Avatar
MIAPLAYA
The new Unichip Q can do this... For instance on the Turbonetics Spec V kit they increased the revlimiter by 400 RPMs..
Old May 16, 2006 | 09:31 AM
Mr.Smallville
Thanks i just found out by Uni CHip that in order to do so i got to mess around with the normal ECU and doing so will void my warrenty so im not gonna mess with it but thanks for all your help
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Rev_Night
Nov 7, 2020 06:00 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
