Timing and Peak Torque
Old Jun 12, 2006 | 12:32 PM
ACEMAN's Avatar
ACEMAN
Master
Default Timing and Peak Torque
Was talking to some guys at the track this weekend. Had the laptop out and was sitting in the car messing with my maps before each run. The one guy said you want to have less timing at your peak torque for more torque.
Is there any truth to this? Should i leave my timing alone at this area or even back it down. Right now it is advanced 2 degrees with the UTEC.
Anyone??
Later
Aceman
Old Jun 12, 2006 | 12:45 PM
Kiamo's Avatar
Kiamo
The timing curve tends to look like the inverse of the torque curve. That being where your torque is highest, timing is lowest. That doesn't mean, however, that jacking down the timing will give you more power there. There's a sweet spot, as always, it'll just be lower than at, say, 6000 RPM.
Really need a dyno to find it accuratly, unfortunatly.
Old Jun 12, 2006 | 12:53 PM
ACEMAN's Avatar
ACEMAN
Master
I will have to play around with it the next time i go to the dyno. Learning more and more Have the A/F where i want it, just need to figure out this timing for the most gains.
Thanks
Later
Aceman
Old Jun 12, 2006 | 06:16 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
usually more timing gives you more tq and more hp, i have my dyno charts and with two degrees adv across the board. it gave me more tq and hp over the whole graph...
Obadabot
Jun 18, 2023 11:31 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
