Dumb question, UTEC base map
Old Sep 28, 2006 | 09:33 AM
chimmike's Avatar
chimmike
Default Dumb question, UTEC base map
Okay, SO, I want to make a base map via some datalogging on my UTEC. I've been advised, however, that if I run on map 0, which is the ecu control, that the car still runs funny. I want to set up a base map and I'm really insure how to go about it. I'll be connecting my innovate wideband and using that other GUI to interface it in with some datalogging.
suggestions?
Old Sep 28, 2006 | 10:29 AM
one350zfan's Avatar
one350zfan
Do you have a MAP sensor hooked up to your utec?
Old Sep 28, 2006 | 10:32 AM
chimmike's Avatar
chimmike
I will, yes.
Old Sep 28, 2006 | 10:38 AM
one350zfan's Avatar
one350zfan
Check your PM
Old Sep 28, 2006 | 11:05 AM
QuadCam's Avatar
QuadCam
my car ran fine on the "0" map. don't try it with larger than stock injectors though!!!
I used the "0" map to see what the ECU is doing during certain situations.....to aid in my tuning.
Old Sep 28, 2006 | 11:08 AM
chimmike's Avatar
chimmike
well this is precisely it, I've got the TN reflash tuned for the 380cc injectors that are in the car right now, so those are essentially stock.
I've just heard from other sources that the car runs weird on 0, but I guess I'll just have to throw it in, make sure I can datalog, and keep it on Map 0 and log it, then make a map as adjustment accordingly.
Old Sep 28, 2006 | 02:10 PM
Gators2001's Avatar
Gators2001
Are you saying "0" acts funny b/c of there being larger injectors or are you saying zero acts like crap period?
I thaught I read alot of the NA guys using zero for some reasons.
Old Sep 28, 2006 | 02:38 PM
chimmike's Avatar
chimmike
I'd just been told that on "0" the utec does funny things to the ecu signal. Maybe I'm mistaken? I haven't personally tried myself, I'm just going by heresay.
Old Oct 1, 2006 | 12:41 PM
SmokyTyrz's Avatar
SmokyTyrz
I've been running on Map 0 for quite a bit now, with no probs. 100% Nismo R-Tune (incl cams and headers, etc) mods here. It runs 100% stock when on Map 0.
Now I have seen some Map 0 logs that suggest the MAF voltage isn't being translated 1:1 as it "passes through", but the offset introduced is only like 0.05 % or something, so it should be negligible unless you are FI.
Old Oct 1, 2006 | 01:01 PM
chimmike's Avatar
chimmike
I'm FI, hence my worries haha
I mean I'd like to get a nice datalog on map 0 if I know for sure i'm not in danger of blowing something on the motor due to odd fluctuations.
Old Oct 1, 2006 | 03:51 PM
SmokyTyrz's Avatar
SmokyTyrz
According to the instructions, Map 0 is technically the bypass map. So if you were running your FI setup on the stock ECU then you *should* be able to do the same on Map 0 with no ill effects.
But I find it hard to believe you are running an FI setup on the stock ECU with any success or smooth running. Is that currently the case?
Old Oct 1, 2006 | 04:51 PM
chimmike's Avatar
chimmike
Turbonetics kit=reflashed ECU.
350z82
Oct 1, 2015 06:25 PM
Alexreyes
Sep 30, 2015 11:30 PM
