ClosedLoop -> OpenLoop transition timing
Old Nov 3, 2006 | 09:21 AM
cersoft's Avatar
cersoft
Default ClosedLoop -> OpenLoop transition timing
Before I start, my car is FI and I'm running 15.5psi on greddy twins ...
So, I'm in the process of fine tuning my umm tune, WOT is super (although I still need to tweak the tempurature compensation numbers) but under 25% throttle (closed->open transition point) about 3250 there is a slight stutter that I'm trying to get rid of.
So, my question is, what should the timing of the 10% column look like, in previous logging runs I noticed that going from the 0% column -> 10% column there was a 20 degree jump in timing, I've changed the timing map to reduce this gap and it does seem to be better, but then again it could be my imagination ...
Also, I get the whole notion that under WOT the timing should be something like 11 btdc at peak tq blending to 15 btdc at peak rpm for example. But what about the timing before peak tq, should it blend from a higher number down to 11 or should it be 11 all the way up to peak tq ... ?!?!?!
Help would be appreciated,
Colin
Old Nov 3, 2006 | 09:40 AM
captj3's Avatar
captj3
First are you running a utec? 2nd I hope you get your answer. From what I've seen in a few threads most people tell you get it tuned by a pro. The best that you will get is a base map. I hope you have better luck in getting answers. No one wants to give out the info when they pay $500-$1000 for a tune. Which I can understand maybe you'll find someone good luck.
Old Nov 3, 2006 | 10:12 AM
cersoft's Avatar
cersoft
Sorry, yes, utec.
Yeah, I know I'm gonna get a bunch of 'go get a tune' answers but what is the point of that, what would I learn. So, if I get answers, then great, if not, well, we'll see ....
Colin
Old Nov 6, 2006 | 08:03 AM
Mike@Altered's Avatar
Mike@Altered
Hey Colin,
For a smooth transition you want to have the timing (stock vs. UTEC) numbers very close to each other. Do a datalog during this transition and you can see what the factory vs. UTEC timing is. If necessary, lower your switch over point to avoid knocking.
Hope this helps,
Old Nov 6, 2006 | 11:26 AM
mistaboosta's Avatar
mistaboosta
well u can also change the transition time length so UTEC does the above mentioned action itself for you
Old Nov 6, 2006 | 12:44 PM
cersoft's Avatar
cersoft
Originally Posted by Mike@Altered
Hey Colin,
Hope this helps,
This is what I figured and I've been slowly but surely closing the gap in the ECU timing values between 0% and 10% columns ...
In regards to the closed -> open loop delay, does this actually work well or is it just best to get the timing nailed in the timing map ?
Colin
Old Dec 16, 2006 | 03:13 PM
q8pianist's Avatar
q8pianist
Hey Colin,
Hope this helps,
can u clear this for me plz ???
do u mean i can see the stock timing numbers ??? plz clear this for me so i can tune the timing perfectly
thanks
Old Dec 16, 2006 | 10:10 PM
QuadCam's Avatar
QuadCam
Colin
personally, I played with both. I think it is better to get the timing number as close as you can. The hard part comes when the ECU changes its timing around, though.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
