how much HP is gained with timing advance (NA)
Old Dec 5, 2006 | 04:46 PM
derek173's Avatar
derek173
Default how much HP is gained with timing advance (NA)
I am about to start self-tuning my 03 coupe with a utec after I install my mrev2 and turboxs tuner. How much HP is to be gained with timing advancement on an NA application? Just wondering because if its like 1-2 hp I might not be so inclined to mess with timing, however if there is potential for 5-10hp it might be worth it .
would a good satey net be just to advance it by +1 and be done so if the ecu is asking for 24 degrees of timing advance and i tell utec to step it up to 25, or should I just just push it to 26, 27,28 untill utec detects knock?
Old Dec 8, 2006 | 01:37 PM
Hella's Avatar
Hella
I did see a gain from advancing the timing but only way up top. Like @ 5000-6000 rpm.
i leave all my tuning to my tuner......but if i learned one thing it is be very conservative with the timing.
Old Dec 8, 2006 | 03:50 PM
Julian@MRC's Avatar
Julian@MRC
If the motor does not need the timind, dont add it.The only way to see if it "needs" the timing is to do a pull on the dyno and start adding timing 1-2 degrees at a time.If it does not make power, then leave it out.
Old Dec 9, 2006 | 05:30 AM
Q45tech's Avatar
Q45tech
The amount of ignition advance necessary to create peak BMEP at 16-17 degrees ATDC varies with individual fuel sensitivity [and spray temperature] and inlet air and head temperature. Temperature affects the burn rate [flame speed]. Fuel is not homogeneous and varies from injector spray to injector spray creating scatter plots around the optimium.
What is right for peak on a dyno is usually too much in the real word because the dyno doesn't fully represent real acceleration load [as the dyno accelerates faster than the same vehicle on the road....in quarter mile].
Whats works in 1st/2nd gear is usually too much for 4th/5th/6th.
Knock sensor software reaction is not instantaneous but contains time constant ramps.
The problem is one cylinder always is the first to knock so without individual cylinder sensing and control [individual fuel and ignition maps] you are always compromised to the worst case.
http://www.mitsubishi-motors.com/cor...004/16E_04.pdf
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Cashwin
Oct 1, 2015 06:36 AM
