Updating UTEC to 2.8d ?
Old Feb 7, 2007 | 09:27 AM
TheMinel's Avatar
TheMinel
right I keep not having any luck. I'm working off a 9V battery, now tried with the USB cable. Drivers installed fine.
WTF is wrong with my utec? Does it HAVE to be on the car to have its software updated or what??? Not impressed.
Old Feb 7, 2007 | 06:30 PM
Madelinot's Avatar
Madelinot
Did you try a BRAND NEW battery? I had the same issue until I used a new battery, which lasts about 30 minutes only...
Old Feb 8, 2007 | 09:18 AM
TheMinel's Avatar
TheMinel
brand new battery yes.
I seem to have found a way to make it work.
I tried to decrease the baud. From the default, decreasing every time it was failing. In between, I unplugged the battery, powering down the UTEC that way, each time.
Finally at 19200 baud, the first file worked! In the process of uploading the throttle control file too.
Old Feb 8, 2007 | 09:23 AM
zluver's Avatar
zluver
Where is the failure occuring??? Is it during the upload? When I used the USB cable I didnt have to change the baud rate or anything. The entire process should only take about 5 minutes.
Old Feb 8, 2007 | 09:26 AM
zluver's Avatar
zluver
Awesome, I'm glad your finally having success. Remember to flip the processor switch towards the logo before doing the throttle file.
Old Feb 8, 2007 | 09:27 AM
TheMinel's Avatar
TheMinel
also did the throttle control file, ok.
now hyperterminal doesnt seem to show anything, and yes I updated the port to the new usb one.
Also flicked the switches back.
any specific setting for the hyperterminal connection when connecting through USB?
Old Feb 8, 2007 | 09:30 AM
zluver's Avatar
zluver
I dont know if the UTEC will actually be able to perform everything off the 9V battery anyway. And when I started up the car I put the serial cable back on to run hyperterminal anyway because the cable is longer. Try that.
Old Feb 8, 2007 | 09:34 AM
TheMinel's Avatar
TheMinel
used to work fine off the 9V battery with the 2.3 software. I managed to save maps, etc to my hd.
My utec is not on the car yet, but I wanted to play with it on my desktop before putting it on the car you see
Old Feb 8, 2007 | 09:37 AM
TheMinel's Avatar
TheMinel
works!!!! needed to press enter for some reason! never needed to press it with the 2.3! weird! but it works!
Old Feb 8, 2007 | 09:40 AM
zluver's Avatar
zluver
I dont know about anything specific for the USB. I was soooo scared to screw anything up that I just used the old cables i knew would work.
Unfortunately, I was not able to upload my old maps either with the serial cable. Kept getting a checksum error even though I changed the map name when I saved them. So you may need the USB cable to upload the maps too. I actually just input one by hand from the old data, which takes ****ing forever!
Old Feb 8, 2007 | 10:02 AM
TheMinel's Avatar
TheMinel
ok, managed to upload maps and copying the parameters by hand after I made a little video of the old ones.
One thing I noticed in the open loop fuelling screen, in the old paramenters I am copying from there were 2 fields called "injector flow" and stock injector flow"
They seem to have disappeared in the 2.8d version? is that normal? it now says "for future use"
also, still in the open loop fuelling screen, there's 2 features where in the old 2.3 said "open loop tps threshold" and the one below it. Now in the 2.8d it only says "feature disabled when the open loop fuelling is disabled" or something similar.
Old Feb 9, 2007 | 11:52 AM
zluver's Avatar
zluver
They changed some of the entries, like injector sizing is no longer there, it is done from the edit map screen. I cant remember if your car is turbo or not, but if it is not you will need to set the Fuel Mode to MAF, load indicator to MAF because the update sets the maps to speed density mode and that makes things look different. If you adjust the timing as well instead of just using the MAF pull up/down mode, and you want to increase rev limit, you will have to set the open loop fuel setting to "1", this will open those features again.
Old Feb 10, 2007 | 03:09 AM
TheMinel's Avatar
TheMinel
my car is NA, and I got the UTEC with a map from Japtrix (got the UTEC second hand). Still haven't put it on the car, was just checking about these differences I found between the 2 differences in the software.
Old Feb 15, 2007 | 05:06 PM
zluver's Avatar
zluver
I took my car down the track the other day and made my first UTEC controlled pass since the test pipes and adjustments to the fuel. Even with conservative timing and terrible 60's (2.3) I increased my trap speed over 1.5mph higher than I have ever hit before, and zero counts of knock. I really cant wait to get this car fully tuned and see what I can run.
Old Mar 4, 2007 | 08:45 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
ok i am having the exact same problem.
when using the serial cable i get the same problem you did. so i go and buy the usb cable. the M16 file when ran does not see anything on the serial port. I really need help bad and i need to get my car runnig again.. it is just sitting in my garage dead because of this POS utec!
i have followed all the steps correctly.
also sometimes when trying the serial cable it says incorrect ID? wtf does that mean?
Old Mar 4, 2007 | 08:59 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
please anyone? if im missing something please let me know? also where are the usb drivers? located in that driver folder? i dont see the execute program? i have xp
Old Mar 4, 2007 | 10:29 AM
TheMinel's Avatar
TheMinel
xp will ask you for the drivers once you plug in the usb cable. Then point to the drivers folder and you'll be sorted.
try different baud rates. unplug the PC cable from the utec every time you trye new baud rates.
TBH it's quite hit and miss, but you'll ge there
Old Mar 4, 2007 | 07:28 PM
  #38
zluver's Avatar
zluver
when it asked me for the drivers I just wrote down the name of the product and went online to find the drivers because I saw no execute program either. i downloaded them to a known file so that when it asked me again I directed it right where to go to find what it needed. That worked and it installed properly. Once the computer was reading the UTEC I had no problems with the other procedure steps. I didnt have to change the other settings at all. Make sure you dont have the serial cable and the USB hooked up at the same time or anything, that might screw it up.
And lastly, go ahead and upload your maps to the UTEC using the USB cable if you can, because the UTEC kept saying my files were corrupt when I tried to upload them, even though they were saved under a different name just as the manual states to do.
Old Mar 4, 2007 | 07:36 PM
  #39
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I just reflashed from 2.6 to 2.8d, and it was a PITA, but I finally got it done. I thinked it may have cured a problem I was having, but it will take a few days to conclusively prove it fixed or not.
Dave
Old Mar 5, 2007 | 05:27 AM
  #40
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
k im still having problems getting the m16 file to see anything with the usb cable it sees noting on any of the ports.
ill try again tonight im going to go buy another cable.
this is RIDICULOUS!
