Need help w/ selecting logging/gauges (probably innovate)
Old Mar 28, 2007 | 05:46 AM
rcdash's Avatar
rcdash
Default How did you set up MAP sensor (for use by UTEC AND gauge display)
Hey all,
With a UTEC on the way, plans for FI but NA tuning for now...
I was going to get the innovate LC-1 set up and display using logworks using the in-car PC/touchscreen setup in my G35 coupe.
I also want to monitor (eventually): oil pressure, fuel pressure, boost, and maybe EGT.
I'm trying to pick the right innovate kit.
1st question: Can the XD16 display different channels "on the fly" automatically and/or can LogWorks have the XD16 alternate displays, particularly if a reading hits an alarm threshold (LogWorks can do this right?).
2nd question: Can the TurboXS MAP sensor be somehow integrated with the Innovate logging functions? Or will I need to get 2 MAP sensors (one for reading by Innovate LogWorks and one for conenction to the UTEC).
Thanks!!!
Old Mar 28, 2007 | 04:53 PM
rcdash's Avatar
rcdash
I think I found the answer to #1: the XD16 can be "configured" to display different channels, but at the moment this is a very manual process. Not sure if LogWorks can be configured to alter the XD16 configuration on-the-fly.
For #2, I could have try to just take the voltage out and hook it up to the innovate serial bridge (through their SSI-4 box) but not sure what effect that will have on the signal being read by the UTEC...
Workshop12
Mar 23, 2020 01:45 PM
speedsniper
Sep 14, 2015 08:46 AM
JmanZ
Nov 5, 2002 11:27 AM
shoalhaven
Sep 30, 2002 06:55 PM
