UTEC logging and showing Knock..
Old Apr 9, 2007 | 11:19 PM
hji1945's Avatar
hji1945
Anyway... After I switched to Closed Loop Fueling mode, tuning got harder.. The AFR values are not really precise (not same everytime).. So.. Don't really know what to do.. I'm doing it for NA.. Should I just done in Open Loop Fueling??
Old Apr 9, 2007 | 11:34 PM
Derek Dee's Avatar
Derek Dee
lurking tuner.
subscribed....
Old Apr 10, 2007 | 11:05 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by hji1945
Thanks.. I'll go see if there is 100 octane in bakersfield.. I only see 2 76 in bakersfield.. HAHA.. Sucks.. If I cut 1-2 degrees of timing.. Will it effect on my HP a lot?
Let me put it this way: if the stock ECU detects knock, it will pull timing out automatically (and then slowly add it back in again. This is for safety). So you might as well pull it yourself, that way the ECU will not "overcompensate" .
Have you dyno'd your car with your current tune?
I'd start by reducing timing by 1 degree and let us know how that goes. You won't lose much HP.
Justin100
Nov 25, 2021 06:26 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
