Race Gas Tune via UTEC Question
Old Apr 10, 2007 | 06:46 PM
Kenk2's Avatar
Kenk2
Professional
Default Race Gas Tune via UTEC Question
Hey fellas..
I am contemplating whether I want to go and get a tune professionally or myself for 2 maps..
I have tuned for pump gas and I feel I am about 85-90% without going to the dyno.
If I was to go ahead and tune for race gas after I was 100% happy with my pump gas map, essentially what is the 'norm' and what can I expect when it comes to tuning for a higher octane?
Advance timing 1 or 2 degrees and maybe 1-1.5 higher boost?
Just advance timing and leave the boost alone?
Add boost leave timing alone?
Thanks for all the replies fellas.. I do appreciate it!
K
Old Apr 10, 2007 | 07:01 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would lean it out to about 12 to 1 and advance the timing max of 1 degree, it will be good for about 30 hp with that combo if done right still safely.
what kinda max timing are you running at redline and peak tq??
Old Apr 10, 2007 | 07:18 PM
Kenk2's Avatar
Kenk2
Professional
Thanks for the reply J I know your busy and do appreciate it..
Code:
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]   [26.5]   [23.5]   [22.5]   [21.5]   [20.5]   [19.2]   [18.2]   [17.2]   [16.2]   [15.2]
   [-100]   [25.5]   [22.5]   [21.5]   [20.5]   [19.5]   [18.2]   [17.2]   [16.2]   [15.2]   [14.2]
   [-100]   [25.2]   [22.2]   [21.2]   [20.2]   [19.2]   [17.9]   [16.9]   [15.9]   [14.9]   [13.9]
   [-100]   [24.8]   [21.8]   [20.8]   [19.8]   [18.8]   [17.5]   [16.5]   [15.5]   [14.5]   [13.5]
   [-100]   [25.8]   [22.8]   [21.8]   [20.8]   [19.8]   [18.5]   [17.5]   [16.5]   [15.5]   [14.5]
   [-100]   [25.5]   [22.5]   [21.5]   [20.5]   [19.5]   [18.2]   [17.2]     [16]     [15]     [14]
   [-100]     [25]     [22]     [21]     [20]     [19]   [17.7]   [16.7]   [15.7]   [14.7]   [13.7]
   [-100]   [23.4]   [20.4]   [19.4]   [18.4]   [17.4]   [16.1]   [15.1]   [14.1]   [13.1]   [12.1]
   [-100]   [24.6]   [21.6]   [20.6]   [19.6]   [18.6]   [17.4]   [16.4]   [15.4]   [14.4]   [13.4]
   [-100]   [23.6]   [20.6]   [19.6]   [18.6]   [17.6]   [16.6]   [15.6]   [14.6]   [13.6]   [12.6]
   [-100]   [23.3]   [20.3]   [19.3]   [18.3]   [17.3]   [16.3]   [15.3]   [14.3]   [13.3]   [12.3]
   [-100]   [23.8]   [20.8]   [19.8]   [18.8]   [17.8]   [16.8]   [15.8]   [14.8]   [13.8]   [12.8]
   [-100]   [23.7]   [20.7]   [19.7]   [18.7]   [17.7]   [16.7]   [16.2]   [15.2]   [13.7]   [12.7]
   [-100]   [25.6]   [22.6]   [21.6]   [20.6]   [19.6]   [18.6]   [17.6]   [16.6]   [15.6]   [14.6]
A log in the next post..
Old Apr 10, 2007 | 07:19 PM
Kenk2's Avatar
Kenk2
Professional
Latest log via UTI
Code:
000.00 1600  -0.8 2.9  100   10   0  16.5  12.7 ECU    0.0 000  2.7  12.98
000.05 1643  -0.7 3.0  100   10   0  16.6  12.7 ECU    0.0 000  2.7  12.88
000.09 1678  -0.7 3.0  100   10   0  16.5  13.4 ECU    0.0 000  2.7  12.82
000.14 1668  -0.6 3.0  100   10   0  19.6  13.3 ECU    0.0 000  2.7  12.69
000.19 1663  -0.6 3.0  100   10   0  19.6  13.4 ECU    0.0 000  2.8  12.55
000.23 1694  -0.5 3.0  100   10   0  19.6  14.0 ECU    0.0 000  2.8  12.44
000.28 1719  -0.5 3.0  100   10   0  17.5  14.1 ECU    0.0 000  2.8  12.32
000.34 1740  -0.4 3.0  100   10   0  16.4  14.3 ECU    0.0 000  2.8  12.20
000.38 1741  -0.3 3.0  100   10   0  16.6  14.3 ECU    0.0 000  2.8  12.15
000.44 1756  -0.3 3.1  100   10   0  15.5  14.7 ECU    0.0 000  2.8  12.01
000.48 1759  -0.2 3.1  100   10   0  16.6  14.8 ECU    0.0 000  2.8  11.93
000.53 1768  -0.1 3.1  100   10   0  16.5  15.3 ECU    0.0 000  2.8  11.90
000.58 1805  -0.1 3.1  100   10   0  16.4  15.4 ECU    0.0 000  2.9  11.83
000.64 1840  +0.0 3.2  100   10   0  16.5  15.8 ECU    0.0 000  2.9  11.72
000.69 1838  +0.0 3.2  100   10   0  14.6  16.2 ECU    0.0 000  2.9  11.67
000.73 1837  +0.1 3.2  100   10   0  14.5  16.3 ECU    0.0 000  2.9  11.63
000.78 1870  +0.2 3.2  100   10   0  14.4  16.3 ECU    0.0 000  2.9  11.55
000.86 1905  +0.3 3.2  100   10   0  14.5  16.5 ECU    0.0 000  3.0  11.49
000.88 1922  +0.3 3.2  100   10   0  14.5  17.0 ECU    0.0 000  2.9  11.49
000.94 1917  +0.4 3.3  100   10   0  15.5  17.0 ECU    0.0 000  3.0  11.45
000.98 1922  +0.5 3.3  100   10   0  15.6  17.5 ECU    0.0 000  3.0  11.45
001.03 1954  +0.6 3.3  100   10   0  15.4  18.9 14.6   0.0 000  3.0  11.41
001.08 1990  +0.6 3.3  100   20   0  15.4  19.1 18.6   0.0 000  3.0  11.31
001.13 1989  +0.8 3.3  100   20   0  16.5  18.3 22.5   0.0 000  3.1  11.05
001.17 1964  +0.8 3.4  100   20   0  16.7  18.1 19.3   0.0 000  3.1  10.96
001.22 2006  +0.8 3.4  100   20   0  16.4  18.8 21.5   0.0 000  3.1  10.75
001.25 2073  +1.0 3.4  100   20   0  16.5  19.0 21.5   0.0 000  3.1  10.63
001.31 2087  +1.1 3.4  100   20   0  14.4  19.1 21.5   0.0 000  3.1  10.51
001.34 2092  +1.2 3.4  100   20   0  14.4  19.6 21.4   0.0 000  3.1  10.46
001.41 2120  +1.3 3.4  100   20   0  14.6  20.1 21.4   0.0 000  3.2  10.43
001.45 2138  +1.4 3.5  100   20   0  14.6  20.7 21.2   0.0 000  3.2  10.44
001.50 2157  +1.5 3.5  100   20   0  13.4  20.5 21.2   0.0 000  3.2  10.51
001.55 2175  +1.6 3.5  100   20   0  11.4  21.0 21.0   0.0 000  3.3  10.76
001.59 2167  +1.6 3.5  100   20   0  10.7  21.8 21.0   0.0 000  3.3  11.03
001.64 2190  +1.7 3.5  100   30   0  11.4  21.7 21.0   0.0 000  3.2  11.19
001.69 2222  +1.9 3.5  100   30   0  10.6  22.2 20.7   0.0 000  3.3  11.29
001.73 2243  +2.0 3.5  100   30   0  10.6  22.6 20.7   0.0 000  3.3  11.37
001.78 2261  +2.0 3.5  100   30   0  10.5  23.5 20.7   0.0 000  3.3  11.43
001.84 2265  +2.2 3.6  100   30   0  12.3  23.7 20.5   0.0 000  3.3  11.45
001.88 2285  +2.3 3.6  100   30   0  11.5  23.5 20.5   0.0 000  3.4  11.45
001.94 2315  +2.4 3.6  100   30   0  11.6  24.4 20.5   0.0 000  3.4  11.44
001.98 2319  +2.4 3.6  100   30   0  11.3  24.2 20.2   0.0 000  3.4  11.39
002.03 2342  +2.6 3.7  100   30   0  12.5  25.0 20.2   0.0 000  3.4  11.37
002.08 2354  +2.6 3.7  100   30   0  11.4  24.8 20.0   0.0 000  3.3  11.39
002.14 2380  +2.8 3.7  100   30   0  12.5  25.7 20.0   0.0 000  3.4  11.37
002.19 2423  +2.9 3.7  100   30   0  12.5  25.2 19.9   0.0 000  3.4  11.34
002.23 2432  +3.0 3.7  100   40   0  13.3  26.1 19.9   0.0 000  3.4  11.33
002.28 2438  +3.1 3.7  100   40   0  12.6  26.3 19.7   0.0 000  3.4  11.33
002.34 2476  +3.1 3.7  100   40   0  12.5  26.1 19.7   0.0 000  3.4  11.33
002.38 2481  +3.2 3.7  100   40   0  12.4  26.4 19.7   0.0 000  3.4  11.34
002.44 2479  +3.3 3.7  100   40   0  13.4  27.4 19.4   0.0 000  3.5  11.37
002.48 2520  +3.3 3.7  100   40   0  13.4  27.6 19.3   0.0 000  3.4  11.37
002.53 2561  +3.4 3.7  100   40   0  13.5  28.2 19.2   0.0 000  3.4  11.36
002.56 2581  +3.5 3.8  100   40   0  13.4  28.7 19.1   0.0 000  3.4  11.34
002.63 2581  +3.5 3.8  100   40   0  15.4  29.1 19.0   0.0 000  3.5  11.33
002.66 2604  +3.6 3.8  100   40   0  15.3  29.1 18.7   0.0 000  3.5  11.33
002.72 2641  +3.8 3.8  100   40   0  15.4  29.8 18.6   0.0 000  3.5  11.30
002.77 2669  +3.9 3.8  100   40   0  15.5  30.2 18.4   0.0 000  3.5  11.30
002.81 2692  +4.0 3.8  100   40   0  16.4  30.8 18.2   0.0 000  3.5  11.29
002.86 2710  +4.0 3.9  100   50   0  16.3  30.7 18.1   0.0 000  3.6  11.26
002.91 2729  +4.1 3.9  100   50   0  15.4  31.3 18.0   0.0 000  3.6  11.23
002.94 2736  +4.2 3.9  100   50   0  16.3  31.0 17.8   0.0 000  3.6  11.23
003.00 2760  +4.2 3.9  100   50   0  16.3  31.6 17.6   0.0 000  3.6  11.23
003.05 2790  +4.4 3.9  100   50   0  17.4  32.3 17.5   0.0 000  3.6  11.23
003.09 2822  +4.7 3.9  100   50   0  17.4  32.7 17.3   0.0 000  3.6  11.24
003.14 2847  +4.8 4.0  100   50   0  17.3  33.0 17.1   0.0 000  3.6  11.23
003.19 2848  +4.8 4.0  100   50   2  16.4  33.4 16.4   0.0 000  3.7  11.23
003.23 2843  +4.9 4.1  100   50   2  17.4  33.2 16.3   0.0 000  3.7  11.26
003.28 2884  +5.0 4.1  100   50   0  17.4  34.3 16.1   0.0 000  3.7  11.28
003.34 2938  +5.2 4.1  100   60   0  17.4  34.4 15.9   0.0 000  3.7  11.33
003.38 2942  +5.2 4.1  100   60   0  17.4  35.2 15.8   0.0 000  3.8  11.34
003.44 2942  +5.4 4.1  100   60   0  17.4  35.6 15.5   0.0 000  3.8  11.39
003.48 2962  +5.4 4.1  100   60   0  17.3  36.4 15.3   0.0 000  3.8  11.40
003.53 3020  +5.7 4.2  100   60   0  17.3  36.7 15.2   0.0 000  3.8  11.44
003.58 3034  +5.7 4.2  100   60   0  17.3  37.0 15.1   0.0 000  3.9  11.48
003.64 3051  +6.0 4.2  100   60   0  16.3  37.7 14.9   0.0 000  3.9  11.54
003.69 3090  +6.1 4.2  100   60   0  16.3  37.9 14.8   0.0 000  3.9  11.58
003.73 3111  +6.1 4.4  100   70   0  16.3  39.3 14.5   0.0 000  3.9  11.61
003.78 3120  +6.2 4.4  100   70   0  17.2  39.4 14.4   0.0 000  3.9  11.62
003.84 3143  +6.4 4.4  100   70   0  17.3  40.5 14.2   0.0 000  4.0  11.67
003.88 3168  +6.6 4.4  100   70   0  17.3  41.1 14.0   0.0 000  4.0  11.67
003.94 3218  +6.9 4.4  100   70   0  16.2  42.7 13.8   0.0 000  4.0  11.68
003.98 3248  +6.9 4.4  100   70   0  15.4  42.1 13.6   0.0 000  4.0  11.67
004.03 3259  +7.2 4.4  100   70   0  15.3  43.7 13.5   0.0 000  4.0  11.62
004.08 3271  +7.1 4.4  100   70   0  15.2  43.5 13.5   0.0 000  4.1  11.61
004.13 3313  +7.7 4.4  100   80   0  15.2  44.8 13.6   0.0 000  4.1  11.58
004.17 3333  +7.6 4.5  100   80   0  16.3  45.6 13.6   0.0 000  4.2  11.58
004.22 3355  +7.6 4.5  100   80   0  16.4  46.8 13.7   0.0 000  4.1  11.58
004.25 3376  +7.6 4.5  100   80   0  16.2  46.5 13.7   0.0 000  4.1  11.58
004.31 3404  +7.7 4.5  100   80   0  16.2  47.2 13.6   0.0 000  4.2  11.53
004.36 3447  +7.7 4.6  100   80   0  16.2  48.5 13.6   0.0 000  4.2  11.49
004.41 3481  +7.9 4.6  100   80   0  16.2  49.3 13.9   0.0 000  4.2  11.49
004.45 3483  +7.9 4.5  100   80   0  16.3  49.6 13.9   0.0 000  4.1  11.48
004.50 3509  +7.9 4.5  100   80   0  15.3  50.1 13.9   0.0 000  4.1  11.49
004.55 3544  +8.0 4.6  100   80   0  16.3  49.9 13.7   0.0 000  4.1  11.45
004.59 3583  +8.0 4.6  100   80   0  16.2  51.4 13.8   0.0 000  4.1  11.45
004.64 3619  +8.0 4.6  100   80   0  15.3  51.3 13.7   0.0 000  4.2  11.42
004.69 3627  +8.1 4.6  100   80   0  16.2  51.4 13.6   0.0 000  4.2  11.39
004.73 3644  +8.2 4.6  100   80   0  16.2  52.4 13.4   0.0 000  4.2  11.37
004.78 3685  +8.2 4.6  100   80   0  16.2  53.2 13.5   0.0 000  4.3  11.33
004.84 3693  +8.2 4.7  100   90   0  16.1  52.9 13.3   0.0 000  4.2  11.32
004.88 3688  +8.2 4.7  100   90   0  16.2  53.6 13.2   0.0 000  4.3  11.29
004.94 3738  +8.5 4.8  100   90   0  16.2  55.3 13.1   0.0 000  4.3  11.27
004.98 3796  +8.5 4.8  100   90   0  16.2  54.7 12.9   0.0 000  4.3  11.27
005.03 3830  +8.5 4.8  100   90   0  16.2  55.6 12.9   0.0 000  4.3  11.27
005.08 3856  +8.4 4.8  100   90   0  16.1  55.0 13.0   0.0 000  4.4  11.27
Old Apr 10, 2007 | 07:20 PM
Kenk2's Avatar
Kenk2
Professional
Code:
005.14 3887  +8.4 4.8  100   90   0  16.2  55.9 12.9   0.0 000  4.4  11.28
005.19 3912  +8.5 4.8  100   90   0  16.1  55.8 12.7   0.0 000  4.3  11.28
005.23 3925  +8.5 4.7  100   90   0  16.1  55.9 12.7   0.0 000  4.4  11.30
005.28 3937  +8.5 4.7  100   90   0  16.2  56.4 12.6   0.0 000  4.4  11.33
005.34 3975  +8.5 4.8  100   90   0  16.2  56.4 12.5   0.0 000  4.4  11.33
005.38 4002  +8.5 4.8  100   90   0  16.1  57.2 12.5   0.0 000  4.4  11.33
005.44 3991  +8.5 4.9  100   90   0  16.2  57.3 12.5   0.0 000  4.4  11.33
005.48 4019  +8.2 4.9  100   90   0  16.0  56.0 12.6   0.0 000  4.4  11.35
005.53 4047  +8.4 4.9  100   90   0  16.2  57.6 12.3   0.0 000  4.4  11.37
005.56 4093  +8.4 5.0  100   90   0  16.1  57.6 12.4   0.0 000  4.4  11.39
005.63 4111  +8.2 5.0  100   90   0  16.2  57.1 12.5   0.0 000  4.5  11.42
005.66 4111  +8.4 4.9  100   90   0  16.1  58.6 12.6   0.0 000  4.5  11.44
005.72 4124  +8.5 4.9  100   80   0  16.1  58.6 12.7   0.0 000  4.5  11.49
005.77 4176  +8.5 4.9  100   90   0  15.1  59.2 12.7   0.0 000  4.5  11.49
005.81 4199  +8.2 4.9  100   80   0  15.2  58.9 12.7   0.0 000  4.5  11.52
005.86 4215  +8.2 5.0  100   80   0  15.1  58.7 12.7   0.0 000  4.5  11.53
005.91 4230  +8.2 5.0  100   80   0  15.1  60.2 12.6   0.0 000  4.5  11.54
005.95 4244  +8.1 5.0  100   80   0  15.0  60.7 12.6   0.0 000  4.5  11.58
006.00 4272  +8.0 5.0  100   80   0  14.1  60.5 12.8   0.0 000  4.5  11.61
006.05 4321  +8.2 5.0  100   80   0  13.2  60.4 12.5   0.0 000  4.5  11.61
006.09 4374  +7.9 5.0  100   80   0  13.0  62.0 12.6   0.0 000  4.5  11.61
006.14 4378  +7.9 5.0  100   80   0  13.0  62.9 12.3   0.0 000  4.5  11.61
006.19 4412  +7.9 5.0  100   80   0  14.0  63.3 12.4   0.0 000  4.5  11.58
006.23 4431  +7.9 4.9  100   80   0  13.0  63.8 11.9   0.0 000  4.5  11.58
006.28 4465  +7.7 4.9  100   80   0  12.2  62.8 12.4   0.0 000  4.5  11.53
006.34 4503  +7.7 4.9  100   80   0  12.1  63.3 12.1   0.0 000  4.5  11.52
006.38 4514  +7.7 4.9  100   80   0  11.9  65.2 12.1   0.0 000  4.5  11.49
006.44 4545  +7.7 5.0  100   80   0  12.1  66.1 11.8   0.0 000  4.5  11.45
006.48 4585  +7.9 5.0  100   80   0  13.1  66.8 11.7   0.0 000  4.5  11.45
006.53 4606  +7.9 5.0  100   80   0  12.9  67.0 11.5   0.0 000  4.5  11.42
006.58 4604  +7.9 5.0  100   80   0  12.9  67.6 11.4   0.0 000  4.5  11.38
006.64 4642  +8.1 5.0  100   80   0  14.0  68.6 11.3   0.0 000  4.5  11.39
006.69 4688  +8.1 5.0  100   80   0  14.0  69.6 11.4   0.0 000  4.5  11.42
006.73 4704  +8.1 5.0  100   80   0  13.9  69.4 11.3   0.0 000  4.5  11.42
006.78 4725  +8.1 5.0  100   80   0  14.1  70.0 11.2   0.0 000  4.5  11.42
006.84 4756  +8.1 5.0  100   80   0  14.0  70.3 11.3   0.0 000  4.5  11.39
006.88 4779  +8.1 5.0  100   80   0  13.9  70.1 11.2   0.0 000  4.5  11.37
006.94 4787  +8.1 5.0  100   80   0  14.2  71.7 11.3   0.0 000  4.5  11.37
006.98 4808  +8.0 5.0  100   80   0  14.0  71.0 11.4   0.0 000  4.5  11.36
007.03 4824  +8.1 5.0  100   80   0  13.8  70.1 11.4   0.0 000  4.5  11.34
007.06 4842  +8.0 5.0  100   80   0  14.0  70.0 11.5   0.0 000  4.5  11.33
007.13 4882  +8.1 5.0  100   80   0  16.1  70.3 11.7   0.0 000  4.5  11.33
007.16 5001  +8.1 5.0  100   80   0  16.0  70.6 12.0   0.0 000  4.5  11.36
007.22 5017  +8.0 5.0  100   80   0  16.0  70.6 12.1   0.0 000  4.5  11.43
007.27 4994  +8.0 5.0  100   80   0  15.9  70.4 12.1   0.0 000  4.5  11.44
007.31 5000  +8.0 5.0  100   80   0  16.0  68.2 12.1   0.0 000  4.5  11.48
007.36 5024  +8.2 5.0  100   80   0  16.0  69.8 12.3   0.0 000  4.5  11.51
007.41 5032  +8.0 5.0  100   80   0  15.8  70.0 12.6   0.0 000  4.5  11.57
007.44 5050  +8.0 5.0  100   80   0  16.0  70.0 12.7   0.0 000  4.5  11.60
007.50 5077  +8.0 5.0  100   80   0  16.0  71.3 12.5   0.0 000  4.5  11.65
007.55 5114  +8.0 5.0  100   80   0  14.8  71.1 12.5   0.0 000  4.5  11.67
007.59 5120  +8.1 5.0  100   80   0  15.0  71.2 12.5   0.0 000  4.5  11.68
007.64 5130  +8.1 5.0  100   80   0  15.0  71.4 12.3   0.0 000  4.5  11.69
007.69 5137  +8.2 5.0  100   80   0  15.0  72.0 12.3   0.0 000  4.5  11.73
007.73 5170  +8.2 5.0  100   90   0  14.9  72.7 12.2   0.0 000  4.5  11.73
007.78 5216  +8.4 5.0  100   80   0  14.9  73.7 12.1   0.0 000  4.5  11.71
007.84 5229  +8.1 5.0  100   80   0  13.9  74.4 11.9   0.0 000  4.5  11.71
007.88 5263  +8.4 5.0  100   80   0  14.0  75.4 11.9   0.0 000  4.5  11.69
007.94 5305  +8.1 5.0  100   80   0  13.9  75.1 11.9   0.0 000  4.5  11.62
007.98 5313  +8.1 5.0  100   80   0  13.9  75.2 12.0   0.0 000  4.5  11.61
008.03 5322  +8.1 5.0  100   80   0  16.9  76.4 11.7   0.0 000  4.5  11.57
008.08 5333  +8.2 5.0  100   80   0  16.8  76.4 11.7   0.0 000  4.5  11.54
008.14 5341  +8.1 5.0  100   80   0  17.8  75.9 11.9   0.0 000  4.5  11.53
008.19 5375  +8.2 5.0  100   80   0  18.0  77.0 11.8   0.0 000  4.5  11.49
008.23 5420  +8.1 5.0  100   80   0  17.9  77.2 11.6   0.0 000  4.5  11.49
008.28 5473  +8.2 5.0  100   80   0  17.9  77.9 11.6   0.0 000  4.5  11.49
008.34 5497  +8.0 5.0  100   80   0  17.8  78.2 11.6   0.0 000  4.5  11.49
008.38 5496  +8.0 5.0  100   80   0  17.9  79.3 11.7   0.0 000  4.5  11.51
008.44 5509  +8.1 5.0  100   80   0  17.8  78.7 11.7   0.0 000  4.5  11.51
008.48 5535  +8.0 5.0  100   80   0  17.9  79.3 11.7   0.0 000  4.5  11.49
008.53 5560  +8.1 5.0  100   80   0  17.8  78.8 11.6   0.0 000  4.5  11.48
008.56 5600  +8.1 5.0  100   80   0  17.8  79.6 11.4   0.0 000  4.5  11.48
008.63 5619  +8.4 5.0  100   80   0  17.8  80.1 11.3   0.0 000  4.5  11.45
008.67 5629  +8.1 5.0  100   80   0  17.9  80.2 11.7   0.0 000  4.5  11.45
008.72 5622  +7.9 5.0  100   80   0  17.8  80.0 11.6   0.0 000  4.5  11.45
008.77 5647  +8.4 5.0  100   90   0  17.9  80.0 11.3   0.0 000  4.5  11.45
008.81 5692  +8.1 5.0  100   80   0  17.9  78.6 11.6   0.0 000  4.5  11.45
008.86 5725  +8.5 5.0  100   80   0  17.9  79.3 11.4   0.0 000  4.5  11.45
008.91 5743  +7.9 5.0  100   80   0  17.8  79.9 11.8   0.0 000  4.5  11.45
008.94 5738  +8.2 5.0  100   80   0  17.7  79.9 11.5   0.0 000  4.5  11.45
009.00 5768  +8.0 5.0  100   80   0  17.9  80.5 11.5   0.0 000  4.5  11.45
009.03 5760  +7.9 5.0  100   80   0  17.9  80.6 12.0   0.0 000  4.5  11.47
009.09 5789  +8.2 5.0  100   80   0  17.9  80.2 12.1   0.0 000  4.5  11.48
009.14 5850  +8.0 5.0  100   80   0  17.7  80.3 11.6   0.0 000  4.5  11.49
009.19 5873  +8.2 5.0  100   80   0  17.8  81.0 12.0   0.0 000  4.5  11.49
009.23 5873  +8.6 5.0  100   80   0  17.9  81.7 11.6   0.0 000  4.5  11.52
009.28 5894  +8.1 5.0  100   80   0  17.7  81.0 12.1   0.0 000  4.5  11.53
009.34 5957  +8.1 5.0  100   80   0  17.9  81.4 12.0   0.0 000  4.5  11.58
009.38 5955  +8.5 5.0  100   80   0  17.8  81.8 11.8   0.0 000  4.5  11.58
009.44 5949  +9.1 5.0  100   90   0  18.6  83.8 11.8   0.0 000  4.5  11.56
009.48 5969  +7.8 5.0  100   80   0  18.7  83.0 12.4   0.0 000  4.5  11.56
009.53 5993  +8.4 5.0  100   80   0  18.7  83.0 12.5   0.0 000  4.5  11.56
009.58 6001  +8.5 5.0  100   80   0  19.0  82.5 12.5   0.0 000  4.5  11.56
009.64 6035  +8.5 5.0  100   80   0  18.9  82.2 12.2   0.0 000  4.5  11.56
009.69 6052  +8.0 5.0  100   80   0  18.8  83.3 11.8   0.0 000  4.5  11.53
009.73 6057  +8.2 5.0  100   80   0  18.7  83.8 11.7   0.0 000  4.5  11.53
009.78 6089  +7.9 5.0  100   80   0  18.8  83.2 12.1   0.0 000  4.5  11.52
009.83 6137  +7.8 5.0  100   80   0  19.0  84.3 11.9   0.0 000  4.5  11.55
009.88 6166  +8.0 5.0  100   80   0  18.7  84.3 11.9   0.0 000  4.5  11.58
009.94 6156  +8.0 5.0  100   80   0  18.7  83.9 11.9   0.0 000  4.5  11.53
009.98 6174  +8.7 5.0  100   80   0  18.9  84.1 12.4   0.0 000  4.5  11.53
010.03 6170  +7.7 5.0  100   80   0  18.9  84.7 12.8   0.0 000  4.5  11.52
010.08 6191  +8.1 5.0  100   80   0  18.7  84.3 12.9   0.0 000  4.5  11.52
010.13 6194  +8.2 5.0  100   80   0  18.8  85.4 13.0   0.0 000  4.5  11.49
010.16 6213  +8.5 5.0  100   80   0  18.6  85.9 13.0   0.0 000  4.5  11.51
010.22 6273  +8.4 5.0  100   80   0  19.3  85.5 13.0   0.0 000  4.5  11.49
010.27 6299  +8.4 5.0  100   80   0  20.7  85.8 13.2   0.0 000  4.5  11.49
010.31 6303  +7.9 5.0  100   80   0  20.6  85.6 13.4   0.0 000  4.5  11.50
010.36 6313  +7.7 5.0  100   80   0  20.6  86.2 13.4   0.0 000  4.5  11.53
010.41 6323  +8.1 5.0  100   80   0  20.9  86.6 13.5   0.0 000  4.5  11.52
010.44 6346  +8.2 5.0  100   80   0  20.8  86.4 13.7   0.0 000  4.5  11.52
010.50 6388  +8.6 5.0  100   80   0  20.7  87.1 13.9   0.0 000  4.5  11.52
010.55 6407  +8.4 5.0  100   80   0  20.6  86.4 13.9   0.0 000  4.5  11.53
010.59 6406  +8.1 5.0  100   80   0  20.7  87.8 13.9   0.0 000  4.5  11.53
Old Apr 10, 2007 | 07:21 PM
Kenk2's Avatar
Kenk2
Professional
My latest challenge is trying to get the Greddy Profec-b in its happy spot to where it holds boost steady up top..
Old Apr 11, 2007 | 04:06 AM
Audible Mayhem
My350z
good job ken, that log looks pretty good. the timing is in a nice safe spot all the way up. if i was letting the car leave my shop, i would highlight the whole fuel map and add about 2 ms to the entire map to get the AFR down just a bit to 11.3-11.4 consistent range.
timing looks good.
depending on what race gas you are looking on using will matter the most. looks like you have a nice platform to begin with though.
Old Apr 11, 2007 | 08:29 AM
Kenk2's Avatar
Kenk2
Professional
timing looks good.
Right on thanks..
K
Old Apr 11, 2007 | 10:30 AM
Ziggyrama's Avatar
Ziggyrama
That is good advice. Adding more boost depends on where you're at currently with respect to your compressor efficiency and compression ratio. Unless you know that, it's hard to say if you'll make more power by adding pressure. It's really easy to fall off the efficiency range, have higher detonation tendency and have minimal gains. More boost doesn't always produce more power.
Above advice is pretty good. Get the fueling closer to optimal torque AFR and bump the timing up a couple of degrees. You can get aggresive with race fuel map since you won't be running it all the time. Unless that is all you run
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
Mattg350z
Oct 2, 2015 06:51 AM
