UTEC Question....
Old May 8, 2007 | 07:30 PM
Abishop's Avatar
Abishop
Default UTEC Question....
Ok, I am tuned for high altitude. I plan on taking a 9 day road trip to california and i wont be getting a tune just for sea level. Will it hurt my car to run my tune for high altitude down at sea level? Should i run the stock map and have my car run lean because of breathing mods? What should i do?
Old May 8, 2007 | 07:35 PM
KPierson's Avatar
KPierson
You may consider tweaking your temp cal factors to make up for it. This would be a 'band aide' but it may be good enough. I'm sure there is a direct relationship between altitude and pressure so if you can figure that out you could possibly calculate how much fuel you need to add and be reasonably close.
Old May 8, 2007 | 07:39 PM
Abishop's Avatar
Abishop
see, i dont do my own tuning and im not having my guy tune or mess with it at all before i go. Is it that big of a deal? if it is i will have him make me a map. im not down to hurt my engine.....
Old May 8, 2007 | 09:21 PM
Kenk2's Avatar
Kenk2
Professional
I am not sure if the car is going to be 'ok' or not..
If your in Colorado, the air is much thinner than at sea level.. If I were you, I wouldn't get into boost at all at sea level if your tuned for Colorado..
Old May 8, 2007 | 10:09 PM
Abishop's Avatar
Abishop
I will still be NA at the time i am going on this trip. So for NA, should i be ok?
Old May 9, 2007 | 06:42 AM
Abishop's Avatar
Abishop
bump
Old May 9, 2007 | 02:09 PM
Abishop's Avatar
Abishop
anyone?
Old May 9, 2007 | 02:15 PM
KPierson's Avatar
KPierson
Have you looked in to the temp cal idea? You really won't know what you need to do until you get there. Make a few low RPM WOT runs and you should be able to see about how much fuel you'll need to add.
Old May 9, 2007 | 06:16 PM
rcdash's Avatar
rcdash
The UTEC should adjust for changes in atmospheric pressure, either in MAP or MAF mode. I would think you would be fine, especially if you are NA.
Am I off here? If you are running off MAF (which is likely since you're NA), as you approach sea level the mass air flow will increase and you'll just move to that part of your tuned map. If you are running off MAP as you approach sea level the air density will increase and you'll similarly move to the appropriate part of your tuned map.
As long as your current map is appropriately tuned for the level of MAF/MAP values that you will be experiencing as you approach sea level, it should be fine. I THINK!
Old May 9, 2007 | 08:12 PM
Kenk2's Avatar
Kenk2
Professional
NA you should be fine.. dont worry about it..
Old May 9, 2007 | 08:19 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
you will be fine if N/A the UTEC will adjust automatically to compensate for the change in air density.
Old May 10, 2007 | 02:51 AM
KPierson's Avatar
KPierson
Never thought about it like that. Then, is he really 'tuned' for high altitude at all????
Old May 10, 2007 | 09:19 AM
Abishop's Avatar
Abishop
Well i talked to my tuner, he said he doesn't tune for air density. So he said i can try my different maps and see what happens. But most likly just run map 0 and let the stock ecu control and make the changes for the change in altitude. Thanks for the input guys!
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Mattg350z
Oct 2, 2015 06:51 AM
SirZaLot
Sep 2, 2002 11:02 AM
