Does anyone get detonation with VDC on?
Old May 14, 2007 | 02:55 PM
One Quick Z's Avatar
One Quick Z
Default Does anyone get detonation with VDC on?
hey guys,
do any of you see knock in your logs or hear/feel detonation when you have VDC on?
Old May 14, 2007 | 03:23 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I don't see how the 2 are related.
Old May 14, 2007 | 08:19 PM
One Quick Z
My car was tuned using the procharger FMU and my tuner told me a while ago that I should run with VDC off to avoid detonation.
I didn't understand it either so I thought I might ask others.
Old May 15, 2007 | 06:16 AM
THE TECH's Avatar
THE TECH
Who is your tuner? Even if there was some correlation, I would think you would want to do the opposite.
Old May 15, 2007 | 06:17 AM
blasian's Avatar
blasian
I don't quite understand.
Old May 15, 2007 | 06:18 AM
redman333's Avatar
redman333
I was thinking the same thing.
Old May 15, 2007 | 08:22 AM
One Quick Z
At this time, I'd rather not disclose who the tuner is, however I will talk to them about the fact that no one else has trouble with this issue on the board.
Old May 15, 2007 | 09:30 AM
fklentz's Avatar
fklentz
I suspect because the VDC cut's engine power by leaning out the fuel. If you're breaking the tires loose under a heavy engine load it is plausible.
Old May 15, 2007 | 10:47 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Yeah I think the VDC cuts fuel.
But it should only cut fuel when you are under very low-load. (wheels spinning)
So shouldn't it be safe even if there is a detonation event...?
Old May 15, 2007 | 11:47 AM
westpak's Avatar
westpak
SFZCC
I assume you are using a Utec which is why you are seeing the knock reading. You usually will get knock reading on the Utec when you hit the rev limit or TCS/VDC kicks in, I think it is more noise from the abrupt cut in fuel/throttle
Besides you shouldn't be running the car hard with TCS/VDC on you know it is going to kick in.
Old May 15, 2007 | 07:20 PM
One Quick Z
I'm actually using the Procharger FMU
I was just told that the car would detonate if I ran it with VDC on.
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
NiQk
Dec 17, 2002 10:48 AM
koolzero
Nov 20, 2002 12:53 PM
audball
Oct 21, 2002 12:00 PM
