Do I need to reflash back to stock ECU before doing FI w/ UTEC?
Old May 29, 2007 | 12:51 PM
DanielW's Avatar
DanielW
Default Do I need to reflash back to stock ECU before doing FI w/ UTEC?
I'm doing a turbo kit on my car and I will be using a UTEC for my Fuel management. I have a base map for the turbo that should put the A/F at around 10.5 but at WOT it goes to 13 or so. Someone told me that the AAM reflash that I got when I was NA is causing this and that I might need to get it flashed back to stock because it could be throwing the utec off. I've also heard from others that the UTEC should be able to "tune out" this issue. Can I just get a definitive answer from someone please?
Old May 29, 2007 | 01:24 PM
DanielW's Avatar
DanielW
bump come on tuner guys
Old May 29, 2007 | 01:26 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The base map is likely designed for the stock ECU, but the UTEC also should be able to tune it out.
Old May 29, 2007 | 04:19 PM
DanielW's Avatar
DanielW
thanks for the no BS answer dude
Old May 29, 2007 | 05:12 PM
skaterbasist's Avatar
skaterbasist
Same situation here...
I am planning on going with the Technosquare reflash for NA, when I have completed all my NA mods.
And in the future, very long future, I will be going Forced Induction with UTEC as my EMS.
I guess the UTEC will be able to work with the reflashed ECU by technosquare.
Old May 30, 2007 | 02:59 AM
DanielW's Avatar
DanielW
thats what i've heard from several sources so far but keep the info coming
Old May 30, 2007 | 10:39 AM
anubyss's Avatar
anubyss
I had a custom flash done by AAM when I was n/a and now am using Utec with my Vortech. I didn't flash it back to stock.
Old May 30, 2007 | 11:14 AM
DanielW's Avatar
DanielW
awesome! thanks for the input
Mike@Altered
Tuning
149
Oct 30, 2009 01:07 PM
failsafe306
Mar 23, 2006 05:54 PM
titanjc
Feb 23, 2006 09:32 AM
dynamic6er
Mid-Atlantic
Dec 5, 2005 02:09 PM
BlackTuner
Nov 14, 2005 12:40 PM
