Need help wit A/F issue
I'm having an odd problem with my 04 G35.
Both A/F sensors read near perfect a/f (approx 13.0) up to 5600 RPM, then the left bank A/F goes lean (off the chart lean like the injector turned off) and the right bank goes rich (approx 11:1).
THE ENGINE FEELS SMOOTH AS GLASS WHILE THIS IS HAPPENING. The engine runs strong.
No DTC error codes come up at all.
Any Idea's on what might be causing this?
Terry
Terry
Originally Posted by RedondoG
OK, I'll check for a leak tomorrow.
Will I be able to detect a leak at low RPM?
So I see you got you you've been waiting for right Terry?
Originally Posted by skaterbasist
If you have a leak, you will hear a hissing sound coming from the source of the leak at idle.
Originally Posted by THE TECH
Maybe a bad cat. I don't recall if you're running test pipes or not.
