UTEC installation question: Molex?
Old Aug 11, 2007 | 07:51 PM
jining's Avatar
jining
Default UTEC installation question: Molex?
Hello, just curious about the 12 pin molex connector with 2 wires. In the manual it says to ground the #1 pin the black one, but it doesnt say what to do with the red wire. Does the UTEC draw power from the ecu or do I tap the red wire to draw power?
Old Aug 11, 2007 | 08:54 PM
Darshu's Avatar
Darshu
The red wire on the molex connector is PIN 7, for spare solenoid control. If you're not using it, just wrap some electrical tape around it and tie it up out of the way.
Old Aug 12, 2007 | 02:03 AM
jining's Avatar
jining
what solenoid would it be used for exactly? Im just going to be running a utec with MAP sensor.
Old Aug 12, 2007 | 09:05 AM
i8acobra's Avatar
i8acobra
Boost control or nitrous. If you're NA, the red wire has no use.
Old Aug 12, 2007 | 05:22 PM
rcdash's Avatar
rcdash
There's actually a separate boost control solenoid line (diagrammed in the back of the UTEC manual). The spare solenoid unlike the boost control solenoid doesn't get it's own map, but it can "activate" based on a number of conditions to trigger things like nitrous as i8acobra mentioned or meth or water spray etc.
Old Aug 12, 2007 | 05:41 PM
jining's Avatar
jining
cool so I wont be needing that thanks!
2ndchanceZ
Oct 26, 2015 08:03 PM
Mattg350z
Oct 2, 2015 06:51 AM
