Scaling Big injectors with UTEC
I installed my 650 cc injectors today and I cant seem to get them scaled, I have a 11.5 afr at Idle and it runs kinda crappy.
On my open loop fueling parameters the Injector scaling column isnt there anymore and the Injector Deadtime parameter is also missing, I am running version 2.8
I am already running -24 in the 0 Load Column, and it doesnt get any better with lower numbers.
Any insight?
Any insight?
Originally Posted by Sharif@Forged
+1
To get the best idle, I would recommend a return fuel system, and about 40-45psi or less of base fuel pressure (vaccum line disconnected from FPR).
yes i am already running the CJM fuel return, I bought it from you Sharif
i will try less fuel pressure, currently i am running ~52 psi base
+1
oh yeah last question, should this affect how much fuel will be delivered at full boost, i seem to be running a bit leaner even after I compensated on the fuel map for the fuel pressure drop.
Originally Posted by rcdash
Are you adjusting the 0% load column?
yeah i got it to -24 right now, everything works fine when the AC is on bc it brings the RPM up. Its back at 14.7 afr, looks like i will have to get the idle raised up, thanks for the info though
Reviving an old thread (I searched):
I just also swapped my APS injectors (380cc??) to RC 650cc. I had all zeros in the 0% column before and it was running just fine. I tried adjusting it to -20, -30 and all the way to -60. It is now running a lot better (idling ~14.7), but it seems to smoke a lot. Can that be because of too much fuel? How low should I adjust it and how low is "too low" in the 0% column? I know all cars are different, I'm just trying to get a feel for what it should be set to. I'm using the stock fuel system and APS fuel pump/regulator.
Thanks!
Thanks!
Hmm...-60 is crazy. I have -21 with RC 650's and a Walbro pump. It throws smoke at the start, but then is fine.
Either you are having an issue with an injector (dumping more fuel than it should), or your fuel pressure is too high.
