How to subtract Timing with Utec?
Old Sep 4, 2007 | 07:47 AM
athenG's Avatar
athenG
Default How to subtract Timing with Utec?
I'm having some knock around 4700RPM at 40 load, I have done lots of logging but in some cases I do get some knock at that area. MY AF is at 11.22 so I'm not leaning out, can someone tell me were/how much to subtract?
This is a 2nd to 3rd gear pull.
Code:
			Load	Knock			Mod
RPM	MAP	TPS	Site	Count	Ign#1	Inj#1	Ign	A/F
	psia	%			deg	duty	deg
6016.00	5.70	92.00	60.00	0.00	16.90	83.10	16.50	11.58
6116.00	6.00	91.00	60.00	0.00	16.80	84.30	16.60	11.69
6195.00	6.20	94.00	60.00	0.00	17.90	87.60	16.40	11.63
6337.00	6.40	95.00	60.00	0.00	17.80	89.30	16.80	11.63
6385.00	6.00	95.00	60.00	0.00	17.80	90.70	17.00	11.29
6510.00	6.00	95.00	60.00	0.00	17.90	91.60	17.20	11.29
6535.00	6.00	0.00	60.00	0.00	22.90	80.60	19.10	11.29
6195.00	-6.70	1.00	0.00	0.00	33.80	11.70	ECU. 	12.49
6027.00	-10.40	1.00	0.00	0.00	34.00	6.50	ECU. 	11.91
5767.00	-11.60	0.00	0.00	0.00	32.00	6.40	ECU. 	11.91
5385.00	-9.50	63.00	0.00	0.00	19.10	43.70	ECU. 	32.91
4623.00	0.30	98.00	10.00	0.00	12.20	35.50	18.50	34.79
4741.00	1.40	98.00	20.00	0.00	12.00	40.40	17.60	12.10
4649.00	2.40	97.00	20.00	2.00	14.00	46.30	17.30	12.20
4741.00	3.40	97.00	40.00	10.00	12.20	55.80	6.00	11.22
4768.00	4.50	98.00	50.00	0.00	6.00	63.60	5.10	11.42
4810.00	5.70	97.00	60.00	0.00	13.00	65.30	9.10	11.42
4975.00	6.60	96.00	70.00	0.00	6.90	70.60	12.60	11.42
4916.00	7.50	96.00	70.00	0.00	10.00	75.60	12.20	11.42
5027.00	7.90	97.00	80.00	0.00	12.90	76.70	12.50	11.42
5096.00	8.10	97.00	80.00	0.00	12.90	79.50	12.60	11.42
5081.00	8.10	97.00	80.00	0.00	12.00	78.30	12.60	11.77
Old Sep 4, 2007 | 08:00 AM
Blackbird CPV35's Avatar
Blackbird CPV35
it looks like you need to take out some timing at ~4600 @ 20% load, it goes from 12 degrees to 14 degrees back to 12, then it knocks, try taking out 2 degrees there and see what happens
Old Sep 4, 2007 | 08:04 AM
rcdash's Avatar
rcdash
No it's worse than that - his modified timing goes up to 18.5. The 14 is the stock ECU timing I believe. Trim that down.
Old Sep 4, 2007 | 08:08 AM
athenG's Avatar
athenG
So do I just go to that exact RPM and Load column and subtract?
Old Sep 4, 2007 | 10:15 AM
Blackbird CPV35
my bad, I dont ever use the UTEC to log, i use the MPS software
why dont you post a screenshot of your timing map
Old Sep 5, 2007 | 10:46 PM
jining's Avatar
jining
Your A/F is at 34:1 at 4600 :|
The Ignition degree goes from 17->6->5->9->12 isnt that a bit odd?
Old Sep 6, 2007 | 05:04 AM
Blackbird CPV35
that looks like where he is shifting, mine goes crazy lean when i am decellerating too
Old Sep 6, 2007 | 06:01 AM
athenG's Avatar
athenG
Yes, I was shifting on that and you can see my TPS going from 0-60% so the utec hasn't fully taken over yet. my timing went from 17-6-5 because of UTEC seeing some nasty knock and it pulled a lot of timing. Since I was knocking at that range (If ever I got any knock), I did pull some timing on the 4750 rpm at 30-40 load column of about 1 deg and I also pulled 1 deg on the 4500rpm at 40 load column. I don't really know whick cell to subtract so I started there and so far no knock yet even with the AC on.
Old Sep 6, 2007 | 06:11 AM
athenG's Avatar
athenG
here's my old map and and I subtracted 1 deg on the bold area.
Code:
4000  [-100]  [20]     [20]     [20]   [19]   [20.5]   [19]   [18]     [16]   [14.5]   [14]
4250  [-100]  [20]     [18]     [20]   [18.5] [17]     [17]   [16]     [15]   [13]     [13]
4500  [-100]  [19]     [17]     [18]   [16]   [15.5]   [14.5] [13.5]   [12.5] [12.5]   [12]
4750  [-100]  [17]     [18]     [18]   [16]   [15.5]   [13.5] [12.5]   [11.5] [12]     [12]
5000  [-100]  [19]     [19]     [18]   [18]   [15]     [14]   [13]     [13]   [11.5]   [11.5]
5250  [-100]  [19.4]   [19.4]   [18]   [17]   [16.5]   [14.5] [13.5]   [13.5] [12.5]   [12.9]
5500  [-100]  [19.4]   [19.4]   [16.5] [16]   [17]     [14]   [14]     [15]   [14]     [14]
5750  [-100]  [21.5]   [21.5]   [17.5] [17]   [16.5]   [15]   [15]     [15]   [15.5]   [15.5]
Old Sep 6, 2007 | 06:33 AM
Kenk2's Avatar
Kenk2
Professional
No because the UTEC pulled timing
Old Sep 6, 2007 | 07:20 AM
TTRANK's Avatar
TTRANK
I would try to pull out 2 degrees in the problem area and see if that helps. It is very warm out right now.
Also are there any big changes in your fuel map in this area? Your A/F might be ok but a big change could still shock the system.
Old Sep 6, 2007 | 07:27 AM
athenG's Avatar
athenG
That is my problem, when I see knock on a specific load and RPM do I just subtract on that cell or do I need to also make changes on the surrounding cell... I was thinking of just adding some fuel first but didn't know how much value to put in.
Here's a part of my Fuel Map.
Code:
4000	[-5.4]	[94.8]	[107.5]	[112.5]	[129.8]	[138.9]	[148]	[163.6]	[178.9]	[180.6]	[187.6]
4250	[-5.4]	[92.6]	[110.3]	[116.3]	[137.5]	[150.2]	[150]	[165.8]	[180.9]	[184]	[187.9]
4500	[-5.4]	[93.3]	[111]	[126.2]	[151.1]	[153.6]	[159.9]	[173.9]	[186.3]	[187.6]	[194.6]
4750	[-5.4]	[93.3]	[111]	[126.2]	[155.6]	[159.3]	[163.9]	[174.9]	[189.6]	[193.1]	[200.1]
5000	[-5.5]	[115]	[122]	[125.5]	[156.4]	[163.2]	[162.8]	[178.7]	[185]	[196.4]	[193.8]
5250	[-5.5]	[115]	[122]	[125.5]	[155.5]	[163]	[165.1]	[184.5]	[187.4]	[198.8]	[196.2]
5500	[-5.5]	[115]	[122]	[125.5]	[156.6]	[163.8]	[167.4]	[184.4]	[191.5]	[205.1]	[202.5]
5750	[-5.5]	[115]	[122]	[125.5]	[156.6]	[163.8]	[165.1]	[182.1]	[189.6]	[202.5]	[202.5]
Old Sep 6, 2007 | 09:04 AM
Kenk2's Avatar
Kenk2
Professional
What I try and do is pull knock from that cell but from others around it too.. See when your driving and are at WOT, your going through your timing map in a linear way.. There is a post made by Julian explaining this but I will try and show you via the map you posted above.. This is what I would do to your timing.. I would change the numbers in red...
Code:
4250  [-100]  [20]     [17.5]     [20]   [18.5] [17]     [17]   [16]     [15]   [13]     [13]
4500  [-100]  [19]     [17]     [16]   [15.5]  [15.5]   [14.5] [13.5]   [12.5] [12.5]   [12]
4750  [-100]  [17]     [18]     [17]   [15]   [15.5]   [13.5] [12.5]   [11.5] [12]     [12]
5000  [-100]  [19]     [19]     [17.5]  [16.5]   [15]     [14]   [13]     [13]   [11.5]   [11.5]
Old Sep 6, 2007 | 09:49 AM
athenG's Avatar
athenG
Great, I'll try that.
Old Sep 10, 2007 | 01:56 PM
__jb's Avatar
__jb
Z + Rear Seat
Does anyone have a link to Julian's post?
Obadabot
Jun 18, 2023 11:31 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
