need help with rough idle/running lean
Old Sep 7, 2007 | 07:41 PM
icedoutis's Avatar
icedoutis
Default need help with rough idle/running lean
Well, I tripped a check engine light, took it into the local nissan dealership, read the code, and it read that it was from bank 1 running too lean. They plugged their tool to the ecu, and read the a/f ratio at idle. It read 136% for the left bank, and 125% for the right bank. They installed a new mass airflow sensor for me, and now they both read 123%. Was told that it should be running at around 100%. Car idles low too. Idle ranges from around 400rpm to 750 rpm. Any suggestions on how to correct this? Engine mods are mrev2, aps plenum, home-made catch can, aps 2.5 test pipes, and aps 2.5 exhaust. Car is a 2006 350z with the rev-up. Thanks
Old Sep 8, 2007 | 05:16 PM
icedoutis's Avatar
icedoutis
bump, any input is appreciated
Old Sep 8, 2007 | 06:10 PM
rcdash's Avatar
rcdash
you need a tune. get an Osiris reflash and add some fuel to take advantage of all those breathing mods you've got!
Old Sep 8, 2007 | 06:11 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
could be a air leak after the MAF.
Old Sep 8, 2007 | 10:28 PM
NETSHARK's Avatar
NETSHARK
+1 I totally agree with Jarred !!
Check your home made catch can it might be the problem, if you`re running it between the PCV Valve and the Lower Plenum check for any leaks, and also check the Driver side check the hose running from the Left side valve cover to the intake Tube After the MAF check it if its lose or something.
Old Sep 8, 2007 | 11:47 PM
icedoutis's Avatar
icedoutis
thanks for the responses. will check in the morning on a possible air leak. Thanks
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
bneumann
Oct 7, 2015 12:16 PM
Darkspy
Sep 7, 2015 09:09 PM
