Air Temp & Humidity: Effects on performance
Old Jul 9, 2007 | 01:48 AM
Nietzsche's Avatar
Nietzsche
Default Air Temp & Humidity: Effects on performance
So when the air is hotter or humidity is up how does it effect the motor. Do you have to decrease timing, add fuel, I'm kind of lost on this and today my car was running like a dog. It was about 95 and fairly humid, it reminded me of before I started modding it. What can I do to adjust these problems out.
Old Jul 9, 2007 | 01:51 AM
Barzten1's Avatar
Barzten1
Id definately add a radiator and even a oil cooler. Just installed my oil cooler tonight so Im not sure how much it helps performance but I noticed a good difference in performance while daytime driving here in the desert after adding my Koyo radiator.
Old Jul 9, 2007 | 02:35 AM
nofeardude87's Avatar
nofeardude87
when temps get high, the ecu will detect this and limit fuel so that you can have a proper air/fuel mixture since hot air means less dense air
It's nothing to worry about. It's a known fact that high temperature will decrease performance in engines
Old Jul 9, 2007 | 04:13 AM
Nietzsche's Avatar
Nietzsche
Yes, but how can I adjust it? Should I dump more fuel into the system? I haven't used it but the UTEC has a temp adjustment.
Old Aug 19, 2007 | 09:51 AM
Cube's Avatar
Cube
Old topic with a dumb question that never went answered... dumping more fuel in would drop even more power. Lean = more power, but also more likely to detonate.
You can't compensate for the weather (aka, hot air will have less density and thus less oxygen required for combustion) other than water/meth injection, so basically, go FI and the intercooler combined with a positive pressure of air (more dense than freezing cold air) will help with your hot air problems
Old Aug 20, 2007 | 07:30 AM
Q45tech's Avatar
Q45tech
Always make sure that the coolant temperature doesn't exceed 199F as the ecu [oem designs] and most aftermarkets start the summer overheat PROTECTION [decrease advance and enrichen AF] even 1F above than number.
Old Aug 24, 2007 | 08:12 AM
zluver's Avatar
zluver
My cool air tune was already a little rich, so when it hit 90 degrees here in Oklahoma the car just felt slow. I took one to two percent of fuel out from 5500rpm to my redline and pulled 1/2 to 1 degree of timing from 5K up and the car felt much better. I was picking up knock above 6K in the hot weather, but that was fixed by those small changes.
Old Sep 5, 2007 | 10:26 AM
Q45tech's Avatar
Q45tech
Summer gasoline is blended differently from May- Sept usually less btu per gallon and changes in flame speed [ignition advance].
Old Sep 5, 2007 | 10:36 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Cube is right. As air temp goes up, air density goes down, and there will be less molecules of oxygen to burn. So your butt dyno is highly accurate. Hotter temps mean less power...period.
Humidty alone has a negligable impact on power production, which is why even the most expensive stand alone ECU do not have a humidity sensor.
Old Sep 5, 2007 | 11:48 AM
TTRANK's Avatar
TTRANK
Here in Phoenix the high summer temps make my car mad so I pull a little timing out every ~month from late spring to peak summer time and then start putting it back in once fall comes.
Old Sep 9, 2007 | 06:20 AM
Q45tech's Avatar
Q45tech
From air density changes alone [11F per 1%] it is usally hard to feel a 33F [3%] change.............look to other additional factors which additively reduce engine output.
Old Sep 10, 2007 | 05:57 AM
gothchick's Avatar
gothchick
UTEC allows for global map temp corrections (I was tweaking my settings this weekend). So as air temp goes up (or down), you can set the UTEC to automatically adjust timing & fuel to your desired specs in the form of % increase or decrease.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SharX59
Sep 27, 2015 09:23 AM
