nonrevup question...is it possible to get more power topend?
Old Dec 28, 2007 | 05:02 PM
baby_ruiner's Avatar
baby_ruiner
Default nonrevup question...is it possible to get more power topend?
first off i tried searching and i cant find anything that gives me a solid answer to my question...
i have a fully bolt on utec tuned 03 m6. on its best pull it laid down 270/265 in 4th (13.0 a/f plus or minus .01 all the way across). i see alot of cars with less tq put down higher hp numbers. i know some of these are revups which i can understand. my hp hits peak and then levels out at 6k until redline. i have seen some non revups do the same, then i have seen some make power until redline. question is: is it possible for the non revup to make power all the way to redline? i can post my dyno and maps i just have to wait for the bf to email them to me after he gets off work). i was just wondering if there was anymore left in her.
mods: feel free to post a link then lock this if i missed something when i searched. my tuner does mostly high powered lsX cars so this was his first go on utec. i wish we had hp tuner, its cheaper and easier to use!
Old Dec 28, 2007 | 05:35 PM
gothchick's Avatar
gothchick
Power to redline? Only if you add cams and headwork (porting, polishing, bigger valves, etc...) Then retune.
Old Dec 28, 2007 | 05:44 PM
baby_ruiner
i figured cams would help im looking at tomei and bc...im going to do that in january sometime...cant really find any dynos for a nonrevup bolton and cammed tuned z anywhere to compare
my tuner is gobs better then the local z shop IMO, he is going to let me use the lift and tools to do the cams and then tune it the same day
i am just wondering if any nonrevups continue with power gain past 6k....
Old Dec 29, 2007 | 03:06 AM
rocks's Avatar
rocks
Heads are fine they flow 344 cfm, better than a supra head. They just need cams to take advantage of it. 1mm oversize valves arent really going to do much unless your looking for like 700+hp.. Jim Wolf makes some huge cams but they are not listed on the site you have to call and ask for them. They are used in alot of 350z NA race cars and high hp forced induction cars.
Old Dec 29, 2007 | 06:00 AM
baby_ruiner
thanks guys i was more wondering about powerband before cams....
Old Dec 29, 2007 | 08:23 AM
SGSash's Avatar
SGSash
Vendor - Former Vendor
I'm wondering if the revup lower plenum will make more top end power and am considering trying it. I know the MREV2 plenum makes a lot more bottom end torque, but for guys revving to 7400+ the factory revup plenum might work.
Of course the cosworth is best for top end power if you can get your hands on one!
edit: headers are very critial for power, long runners and a good collector is key. it seems the best bolt on headers are the crawford ones (i think its crawford? i might have the name wrong).
Old Dec 29, 2007 | 01:50 PM
gothchick's Avatar
gothchick
Hey, I noticed in your sig you have s7 revup cams and a built engine... I'm about to pull the trigger on a build. Do you by chance have any dyno sheets and a list of your mods? Thanks, Erin.
Old Dec 29, 2007 | 07:12 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
If you have seen that your Z dynos less than others, it is possible that it may simply be due to that particular engine build.
Even stock, they can vary in power output. I had a REVUP engine get replaced due to oil consumption.
The replacement engine I recieved had about 5-8 HP less HP. And no matter what I tried to do to make the plots match, by creating and re-creating the same test conditions, matching the plots couldn't be done.
The new engine simply had lower output.
Old Dec 30, 2007 | 03:45 AM
OCG35's Avatar
OCG35
hmmm.. so ther IS such thing as a Friday engine...
I'll look at mine... I'm certain it was built on the "8th" day" - but the one between Friday and Monday...
Old Dec 31, 2007 | 05:26 AM
baby_ruiner
i wouldnt consider my engine weak at all....265 ft lb tq is pretty amazing considering the tq numbers i have seen on cars putting out higher hp numbers. guess i was extpecting a little more above 6k rpm but that is soon to change....
and let the JDM gods rejoice, i just landed a killer deal on some 264 tomei cams...now just need to score the JWT valvetrain (umm CHADBEE get your booty working!) and ill be good to go!
Old Dec 31, 2007 | 05:41 AM
Hydrazine's Avatar
Hydrazine
Be sure to post dynos of your cam and valve results!
Old Dec 31, 2007 | 06:04 AM
baby_ruiner
this i will or at least ill pm it to you. i have the 5/16th spacer on my car and i know that makes you motordyne guys happy. i havent seen any full bolton plus cams plus tune dynos on the boards so this will be intresting. should be mid january before this gets done, my tuner is running around in the snow up north somewhere for the holidays
Old Dec 31, 2007 | 06:16 AM
rocks's Avatar
rocks
I had to do it again i would of got bigger cams. With the S7 cams it idles and runs fine get the bigger ones i think they are the C8 cams and then get the cam timing done with someone that can tune with the uprev software.
Old Dec 31, 2007 | 07:56 AM
baby_ruiner
s7 cams are for revup engines am i right? i have the nonrevup. i would have liked the 268 cams but i got an AMAZING deal on the 264 cams. plus it a DD for the next 8 months. but spray is in the future so i think it will make a nice combonation
Old Dec 31, 2007 | 08:27 AM
gothchick's Avatar
gothchick
Yeah, S7 (262) & C8 (272?) are for revups...
Old Jan 4, 2008 | 01:14 PM
baby_ruiner
that sounds right...i will post pics of the install when i get my valve train in. its been hell convincing one of my nissan tech friends to help me on the install but one finally gave in good thing is its at the same place as the lsX shop/my tuner/dyno so we can hack it out in two days...hopefully
Old Apr 25, 2008 | 07:03 AM
Partyboy25's Avatar
Partyboy25
ever get all this worked out?
Old Oct 29, 2008 | 12:59 PM
tylerxfire's Avatar
tylerxfire
whats up with this? and what are the mods exactly on the car
Old Oct 29, 2008 | 01:23 PM
mw9's Avatar
mw9
updates
Old Oct 29, 2008 | 02:45 PM
OCG35's Avatar
OCG35
cams helped my non-revup DE top end (a bit)
https://my350z.com/forum/na-builds/3...installed.html
