nonrevup question...is it possible to get more power topend?
Old Oct 29, 2008 | 05:21 PM
scmtkings4's Avatar
scmtkings4
what helps more low end power and torque? most of the things seem to focus on peak numbers
some more grunt 2k-4k would be nice
Old Oct 29, 2008 | 05:53 PM
OCG35's Avatar
OCG35
shorter ring & pinion gears - 3.692 FD for AT, 3.9 or 4.03 FD for MT...
I have an AT with 3.692 (3.7) - also, HFC (I use Crawford) with A/F adjusted gave notable trq...
I recently installed Crawford headers (when I did cams) - power gains across the rmp - 8-10 trq across relatively good curve.
plenum spacer is decent gains pretty much whole rmp and highly debated tbs (throttle body spacer) at least the one I use gave similar felt gains
I'm not going to debate any of these - I have them all and I'm telling stating what has worked for me... I've posted about all of them either here and/or on driver.
all the breather mods will benefit highly from a tune.
If you are looking for one bang for buck idea, I'd go FD gear… A+ on fun to drive factor.
Old Oct 29, 2008 | 08:18 PM
scmtkings4's Avatar
scmtkings4
i def want the fd but the whole process is going to be very troublesome because of the fact that mine is AT. im gonna need to find an MT pumpkin and then get the gears and then get the install kit and then find a reliable shop to do it
and dont you lose a bit of low end with hfc? i have that on already anyway
i would love to do cams/headers/pistons/rods/tune haha i can go on and on. but i should settle down because of how much money this is going to be.
but i could narrow it down to the FD. that i do want.
Old Oct 30, 2008 | 09:14 AM
OCG35's Avatar
OCG35
since you have an AT too... you might want to consider LSD - depending on your budget you cold do Quaife and FD at same time, it bolts right up to your existing pumpkin without having to swap or deal with stub axles, etc... That’s what I did - FWIW.
Old Oct 30, 2008 | 05:44 PM
scmtkings4's Avatar
scmtkings4
wait i thought the 3.7 FD requires a MT pumpkin? i thought the 3.7 wouldnt work with the AT pumpkin?
Old Oct 30, 2008 | 06:33 PM
tylerxfire's Avatar
tylerxfire
well i am manual, and i am motor, not F.I. but will be spraying 100 shot sometimes, what should i go with for gears to run the best times at the track
Old Oct 31, 2008 | 08:13 AM
OCG35's Avatar
OCG35
if you use an MT diff you are fine... that why I suggested Quaife because it will wrok with what he has and allow for 3.7 - I did it in my AT.
Old Nov 1, 2008 | 09:12 AM
scmtkings4's Avatar
scmtkings4
Originally Posted by OCG35
you cold do Quaife and FD at same time, it bolts right up to your existing pumpkin without having to swap or deal with stub axles - FWIW.
sorry i dont quite understand. I was under the impression that in order to put in a different gearing on an AT, you MUST MUST buy a MT diff first, before you could put it in.
youre saying you could bolt the fd + quaife in my existing pumpkin, which would be an AT pumpkin? sorry just a bit confused
Old Nov 1, 2008 | 10:57 AM
j.arnaldo's Avatar
j.arnaldo
I have an AT in my 'O4 Touring Coupe, and the 274ft-lbs of torque give the 287 horses
plenty of punch for the buck. Perhaps it's my age (59), but I'm more than satisfied with
my Zed's pick-up and passing power! I plan to keep that monZter till it goes bust! A drop-in K&N filter helped a bit, too--at least on the MPG department, 'cause I'm gettin' 2 weeks out of a tankfull!
____________________________________________________________ ______________
'O4 Touring Coupe: Flawless AT. No feathering. No oil-consumption issues. NO PROBLEMO
Old Nov 1, 2008 | 08:29 PM
OCG35's Avatar
OCG35
yes, that’s what I'm saying... the Quaife is MT... the only difference between MT and AT FD is the gear is thicker for AT - but the Quiafe is designed for 3.5+ so you're good to go wit 3.692 FD.
There's a bunch of info all over the various forums (there are other forums besides this one ) - you'll get all the info you need to make the right decision... all the questions you are asking are out there
Old Nov 1, 2008 | 08:33 PM
OCG35's Avatar
OCG35
those numbers are measured from the crank I take it (OEM numbers)... you didnt dyno those numbers on a stock car...
anyway - rear end gears dont change your hp & trq - they just change how its transfered to the wheels... put a shorter FD in and you will be passing even quicker
Old Nov 1, 2008 | 08:50 PM
tylerxfire's Avatar
tylerxfire
you seem experienced with the gears, i will be motor for everyday driving and would really like a little more which i take it gears are a great improvement, everyone seems to be happy, but i will be spraying 100 shot when i go to the track which is quite a bit. . any suggestions?, stay stock fd or 3.9 or other, i am manual 6spd. 2003 z.
loudtoyz
Apr 6, 2023 04:52 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
