Haltech Tuning: Can't Get a Stable Idle!!!!!!
Old Mar 6, 2008 | 05:02 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Glad to see Hal is doing his job If you have any questions please don't hesitate to call us.
Old Mar 6, 2008 | 11:47 PM
overZealous1's Avatar
overZealous1
well finally after finding some time tonight, almost have a totally solid idle. only roving about 100rpm now from 1000-1100. this is with 1000cc injectors also. almost cleaned it up enough to prevent it from dipping under that at all on decel also. just takes a little time to find the sweet spot. a little more time and it should react like a stock car in all aspects in that range. yes, i will not stop till it is perfect, lol.
Old Mar 7, 2008 | 06:52 PM
overZealous1
hmm, did the copy through on just the timing map from -2 down after making the above adjustments, and this thing is really close to stock now. idle is good and smooth and tip in is really crisp.
Old Mar 7, 2008 | 06:58 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I did the copy through on 0 psi and below on the fuel map, and it was great. Then, I did the copy through on the ignition map on 0 psi and below, and it is even better. Also, unlike my UTEC, I can't feel any transition when it goes from copy though to Haltech control.
Old Mar 7, 2008 | 07:18 PM
overZealous1
i am trying to just get my driveability good till i can tune it on a dyno 2 weeks from now. so it needs some smoothing in the transition right now.
Old Mar 7, 2008 | 08:05 PM
rcdash's Avatar
rcdash
The copy through does not utilize any kind of injector scaling, does it? (like a piggyback at no load) Even if tuned in VE?
Old Mar 7, 2008 | 08:24 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
To the best of my knowledge, the copy through literally copies the exact values the stock ECU uses for those load points, with no scaling.
However, it is making a nice steady idle on copy through for me, even though I have 440 injectors. Admitedly, 440's aren't all that much bigger than the stock 280's, but I would think it would affect the idle somewhat. My idle is perfect with the copy through, though.
Old Mar 7, 2008 | 08:39 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Dave, You're gonna have to show me this while I'm home. Sounds like you're really happy with the HalTech. Kinda waiting for a long-term review. Looking to upgrade EMS in Aug/Sept when I'm home for good.
Old Mar 8, 2008 | 07:46 PM
overZealous1
running 1000cc injectors here, so copy through on the fuel map is out of the question. but, on the ignition map (and running 8.8/1 comp) running copy through should be perfectly safe in the vacuum load areas till more dyno tuning can be done.
Old Mar 10, 2008 | 08:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hey, using copy-through is cheating...............LOL j/k
Glad you got everything squared away. As mentioned, the Haltech gives a ton of control, and its various maps and correction tables take some time to get used to. Good work!
Old Mar 11, 2008 | 03:49 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yeah, thats what I thought at first, but then realized that with only 440's, it wasn't a big deal, and gave me a great idle and throttle tip in. And I prefer to think of it as "using all available resources....
Old Mar 11, 2008 | 07:08 AM
Sharif@Forged
Forged Performance
ROFL...I like that one.
Old Mar 11, 2008 | 02:19 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Besides, not all of us are gods at tuning. My vast tuning experience is limited to one single car....mine. And some reading, but thats about it.
liqalu04
Jan 2, 2022 12:58 PM
