Aftermarket Enginemanagment debate.
Old Mar 10, 2008 | 10:18 AM
track1z's Avatar
track1z
Default Aftermarket Enginemanagment debate.
Since the ECU is bascially a computer.Why hasn't a program been made to take over the dutys of a human tuner.
Old Mar 10, 2008 | 10:20 AM
Driven1's Avatar
Driven1
Professional
1)No 2 cars are the same, regardless of similar set-ups.
2)People like customizing their set-ups to their driving habits. Making it pointless.
Old Mar 10, 2008 | 10:25 AM
App6MT's Avatar
App6MT
Osiris will have a self tuning feature from what I was told.
Old Mar 10, 2008 | 08:59 PM
track1z's Avatar
track1z
Default hmmmmmmmmm
Maybe this is abit over your head. The point I was tring to explain was that when you run your car on a dyno you set Fuel,ign curve and so on to keep the motor running happy.All this is manually put in by a human.Now what if a program was made to adjust those curves while your on the dyno?SO basically you set in a basic map,run the car then let the Computer do the adjustment and figuring.
Old Mar 18, 2008 | 03:58 PM
JOEGYVER's Avatar
JOEGYVER
It has, just not for the Z/G. The RX7 guys and 1zz/2zz toyota owners utilizing the Apexi power FC have had this ability for about two years now. It references a base map for a variety of parameters, gets feed real time inputs values and calculates the percentage change necessary to maintain the preset values, and then loads the new numbers into the map(s) and does this continuously, just like a closed loop oxygen sensor output manipulates your injector duty cycles. Im so jealous-
Old Mar 18, 2008 | 04:19 PM
rocks's Avatar
rocks
Megasquirt will auto tune off of a wideband o2
Old Mar 21, 2008 | 11:29 PM
overZealous1's Avatar
overZealous1
lots of ecu's will do target a/f. only one i know that will do timing AND fuel is supposed to be the pro-efi. still doing beta testing though and no real release date yet.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
