connecting to utec issues
Old Mar 24, 2008 | 12:59 PM
HoldThisForMe's Avatar
HoldThisForMe
Default connecting to utec issues
quite simply...i cant...
I hyperterm with the settings that it says to use and i get nothing...
so has anyone else had this problem??? any hints or other things i can do?
I have tried both the USB and Serial with same results
Old Mar 24, 2008 | 01:06 PM
JonnyC's Avatar
JonnyC
I connect through USB and it works just fine. Is the UTEC in the car and powered on, or is it out of the car and you are using the 9v? If the latter, make sure to use a good 9v. I used a new but crappy one and I couldn't connect.
Did you try hitting 'enter' or 'esc' after connecting? That will refresh the screen.
Make sure you know what COM port your connected on. Go to the Windows Device Manager (if you know how to get there), and expand the 'COM' section and you'll see what COM port the USB connection is on.
Old Mar 24, 2008 | 02:54 PM
Quamen's Avatar
Quamen
After talking with JonnyC, I just connected the USB cable to the UTEC and used the autoinstall feature to search the disk for the correct driver and install.
Hooked right up after I set the hyperterminal properties and COM port correctly.
Old Mar 24, 2008 | 06:24 PM
HoldThisForMe
hmm ill just keep trying then...and its still in the car...hope its gettin power lol
Question...IF lets say the utec was to just go bad...would the ECU then take back over??? or would it just not run at all???
Old Mar 24, 2008 | 07:40 PM
JonnyC's Avatar
JonnyC
Sorry, don't know the answer to this question. However, my assumption is that everything would crap out on you.
As for the USB connection - did you download the UTEC Zip file that includes the USB drivers? If using a Windows XP pc, when the UTEC is powered up (ignition on) and the usb cable is plugged into your pc, you should be prompted with "Found New Hardware" and then can select the drivers (WIN folder after unzipping the files).
Keep us updated.
Old Mar 24, 2008 | 07:41 PM
Quamen's Avatar
Quamen
Keep us updated.
I didn't even have to unzipp my files and it worked!
Old Mar 26, 2008 | 03:18 PM
HoldThisForMe
ok thanx guys i got connected!
Now heres another for ya haha..
I have version 2.4
Should I update to the 2.8?
Also does anyone have an FI Datalog that I could compare mine too so I can see whats going on??? Im running crazy lean under WOT at full boost and it seems only 50% duty cycle is the highest it goes...BUT I dont go all the way up through the rpms for obvious reasons...but at near 5000rpms WOT full boost im still at aroun 50% dutycycle on the 440cc injectors...
Old Apr 2, 2008 | 06:21 AM
armt350z's Avatar
armt350z
What do you mean by crazy lean? what AFR's are you seeing and what are you using to datalog the afr? Also 50% duty cycle on injectors isnt bad. it means your injectors are sized right to the amount of fuel the ecu is saying to deliver. you should never try to max out injector duty cycle, the maximum I would go for my comfort is around 80%
Old Apr 2, 2008 | 07:28 PM
QuadCam's Avatar
QuadCam
YEs update!!!! The older versions had wierd issues of pulling fuel/timing values from random load columns!!!!!
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
