Reflash using a Nissan scanner ?!?
Old Jul 10, 2008 | 12:28 AM
xav_350z's Avatar
xav_350z
Arrow Reflash using a Nissan scanner ?!?
a friend of mine took his 2005 Z to nissan to install his Popcharger and test pipes...
The guy there told him that he can raflash his ECU using a scanner they have...
Took him like 5 min without even driving the car, and my friend told me that he did feel the diff...
Is it possible to tune ur Stock ECU using a scanner ? i mean its a diagnostic tool...
what do you guys think ?
Cheers!
Old Jul 10, 2008 | 03:22 AM
C5TT's Avatar
C5TT
He probably advanced the timing a couple of degrees, that you can do!!!!!!!!!!! but i dont know of anything else. my tech did that to mine with the consult II, but i have to run 93 octane, otherwise the computer would retard the timing back(knock sensor you know). you do feel the difference though.
Old Jul 10, 2008 | 04:45 AM
xav_350z's Avatar
xav_350z
^ exactly , thats most probably what he did...
btw if u reset ur ECU u'll loose the reflash....
Old Jul 12, 2008 | 06:11 PM
twitch579's Avatar
twitch579
If u advance your timing 2 degrees then reset the ECU it goes back???
Old Jul 12, 2008 | 09:05 PM
__jb's Avatar
__jb
Z + Rear Seat
Resetting the ECU doesn't change the settings the ECU was flashed to.
Old Jul 13, 2008 | 05:28 AM
twitch579's Avatar
twitch579
Sooo anytime u make any ECU changes wether it be idle speed or timing advances with either a Consult or Cipher u are actually flashing the ECU?
If the ECU needs to be flashed that leads me to believe that its a EEPROM sorta like a bios chip on a motherboard for a computer. Pulling the power on the chip for however long will not change its program.
Or pulling the power on it could could erase and changed settings is my other guess.
Old Jul 13, 2008 | 05:47 AM
pmohr's Avatar
pmohr
I wouldn't really call it a reflash as all you're doing is changing a few base parameters (idle speed, ign timing, etc). Technically it could be considered a 'reflash', but most wouldn't.
For the OP's story there could've been an updated ECM program out for his car, but you can't really do much at all with the CONSULT-II beyond diagnostics (spent almost a whole day playing around with the thing back when I first started working at Nissan). Certainly no tuning performance-wise.
And correct, any changes you make to the ECM will not be lost if it loses power. Think of it as a flash drive of sorts.
Old Jul 16, 2008 | 11:49 PM
jining's Avatar
jining
+1 he probably did the idle air volume learning or something Maybe there was an ECM reflash like pmohr suggested but I dont recall one for the 350z I work @ nissan too... woooo
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
