Perfect N/A Air/Fuel
Old Oct 5, 2008 | 01:21 PM
UpRev's Avatar
UpRev
Originally Posted by bswanny
I'm N/A and running 10.0 to 9.9 on WOT. How can you change this? I have a Cobb Accessport, would that work? Thanks.
Osiris Standard and an eTune would fix that right up
Or Osiris Tuner, if you're capable of tuning yourself.
Old Oct 6, 2008 | 07:28 AM
silver350tn's Avatar
silver350tn
is the access port activated for your car? if so and its on a map thats stupid rich for a pre tune
Old Oct 7, 2008 | 05:27 AM
bswanny's Avatar
bswanny
Yeah, Its loaded on one of there maps, and that was exactly my thinking. Any ideas how to fix this?
Old Feb 22, 2010 | 10:55 AM
arsey51's Avatar
arsey51
I did the Cobb Access Port this weekend. My air fuel ratio is right above 10. My HR motor is with the JWT Dual Air intake and the Invidia Gemini cat back. I did pulls on a Dyno Dynamics Dyno. First pulls with stock map was 244. Stage 1 map netted 255, with air/fuel ratio bouncing between 11 and 12. Stage 2 map netted a pull of 262 with air/fuel ratio hovering just above 10. Is 10 too rich, and if not increased, what potential problems could I have down the road. Should I have the air fuel ratio be tweaked to 12 or 13? What's too lean?
Thanks for all or any input/responses.
Old Feb 25, 2010 | 09:37 AM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
what we've seen on af side on tuning the vq's is right around 12.0-12.6 af being a good safe margin of power.
Old Apr 23, 2010 | 05:01 PM
dyna962007's Avatar
dyna962007
That is WAY to rich at WOT.
Of course the Cobb will fix that.
Are you even running a base map now??
Old Apr 24, 2010 | 03:43 PM
screener's Avatar
screener
"Perfect" is not possible, without potential damage to the motor. Given different climate and altitude. Also depending on how aggresive you want to be with + timing. Now there is ideal, to your vehicle. N/A takes well to 13.1 or so given timing/ knock is under control.
hulkout
Tuning
Sep 30, 2015 12:33 PM
