UTEC running rich need help asap
Old Sep 5, 2008 | 02:14 PM
alltel350z's Avatar
alltel350z
Default UTEC running rich need help asap
My setup is a aps st kit with walbro 255 and 600cc dworks. The car will start and idle but keeps a 10.0 to 10.6 a/f. It seems like no matter how much fuel my tuner takes out it still runs the same a/f. Its like it has no response. The utec is set to map 1 while tuning on map 1.
Old Sep 5, 2008 | 02:20 PM
blueper4mancez's Avatar
blueper4mancez
maybe your wideband is not reading correctly ?
Old Sep 5, 2008 | 02:44 PM
alltel350z's Avatar
alltel350z
he thinks he may have found it. something to do with switch 9 controls map 1 or something.
The wb is reading correctly bc you can smell and see the fuel.
Old Sep 5, 2008 | 02:47 PM
blueper4mancez
i see g/l with everything . give sharif a call or pm he'll help you out with it very friendly guy .
Old Sep 5, 2008 | 05:49 PM
frankie945's Avatar
frankie945
When I tried to tune my utec with some 600cc I was told just to adjust the 0 percent column and had the TN fuel map from XS site. No mater what I did it ran rich so I towed it to the tuner and he adjusted all the columns and almost kept all my orginal 0 percent column. And it idled great. I thought it was the car but it just took a good tuner. And what WB are you using? I recommend the tuner pro because it's great for logging with utec.
Old Sep 5, 2008 | 06:09 PM
JonnyC's Avatar
JonnyC
Make sure that the switch on the UTEC itself is set to 0, while the map switch is set to 1.
Old Sep 6, 2008 | 05:04 PM
alltel350z's Avatar
alltel350z
Its weird that switch one does not operate map one but that was the problem.
2ndchanceZ
Oct 26, 2015 08:03 PM
