350z Programmer help
Old Oct 18, 2008 | 08:44 PM
bldg250z's Avatar
bldg250z
Default 350z Programmer help
Im getting ready to buy a Programmer for the z, can anyone recommend a programmer i can get.
Old Oct 18, 2008 | 09:48 PM
Welcome. What is a programmer? What are you programming?
Old Oct 18, 2008 | 11:27 PM
DracoLancet04Z's Avatar
DracoLancet04Z
u talking about an EMS?
Old Oct 19, 2008 | 02:11 PM
bldg250z's Avatar
bldg250z
Default response
I'm talking about a superchip or performance programmer for your ecu to increase horsepower and to be able to adjust your power, air flow andoter things taht can be adjusted from factory tuning.
http://www.cobbtuning.com/products/?id=3686
this is one i was looking at from cobb tuning
any direction on whether using this one or not would help
thanks
Old Oct 19, 2008 | 02:26 PM
civic4982's Avatar
civic4982
try uprev's osiris tuning.
if you're in brownsville, TX then they're in Austin and are a great tuning solution that is popular with many members on here.
Old Oct 19, 2008 | 05:11 PM
cdoxp800's Avatar
cdoxp800
Go here
http://www.uprev.com/
Old Oct 21, 2008 | 09:10 AM
bldg250z's Avatar
bldg250z
Default good or bad
is it a bad idea to remove my ecu and send it to uprev or should i buy the programmer that i can adjust at my need
Old Oct 21, 2008 | 11:28 AM
UpRev's Avatar
UpRev
It's really up to you, the $400 Osiris Mail in Flash Service is inexpensive and we can match the base tune to the mods you specifically have. Cheaper than the competition, with slightly better choice in base tunes, plus we offer Map Switching.
The better solution is Osiris Standard for $700 that comes with the Cipher cable and 3 free eTune updates. That allows us to actually create a tune for your specific car based on data collected from your vehicle. No one else has the exact same car so we can get a bit more power and efficiency out of this tune than we can with the Flash Service. It's more expensive but you also get Cipher so that you can update any time you feel you'd like to, and you get to see what is going on with your car. The Data Logging and Diagnostic functions will help you to make sure your car is always running its best.
Osiris Tuner is available if you want to tune your car yourself or if you have forced induction and need full control over your ECU.
Old Oct 21, 2008 | 03:06 PM
Darth_Z's Avatar
Darth_Z
wow uprev huh y not cobb isnt it dA same?????????
Old Oct 21, 2008 | 03:09 PM
bldg250z's Avatar
bldg250z
thanks ill probably take a drive up to austin and the cipher cable sounds like you can get more options with that. i know depnding on your cars setup do you know how much gain in horsepower i can achieve with this upgrade?
Old Oct 21, 2008 | 03:11 PM
bldg250z's Avatar
bldg250z
i suppose so but i can have hands on direction when tuning thru uprev i suppose and have updates available.
Old Oct 22, 2008 | 04:06 PM
cdoxp800's Avatar
cdoxp800
not even Close..
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
