Setting in Cipher to Monitor AF?
Old Dec 25, 2008 | 11:08 AM
twitch579's Avatar
twitch579
Exclamation Setting in Cipher to Monitor AF?
I have cipher and want to monitor my AF ratio but theres like 10 different things that are AF related. Whats the right one to monitor to see what it is while running?
Thanks.
Old Dec 26, 2008 | 05:48 AM
twitch579's Avatar
twitch579
Anyone!!???
Old Dec 26, 2008 | 10:05 AM
twitch579's Avatar
twitch579
Figured it out, thanks a bunch guys for the overwhelming responces!!!
Old Dec 28, 2008 | 11:51 AM
civic4982's Avatar
civic4982
So which was it that worked for you?
Old Dec 28, 2008 | 01:42 PM
twitch579's Avatar
twitch579
Af Ratio Bank 1
Af Ratio Bank 2
Old Dec 28, 2008 | 01:48 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by twitch579
Af Ratio Bank 1
Af Ratio Bank 2
Dead on..
Old Dec 31, 2008 | 09:32 AM
BrazenZ's Avatar
BrazenZ
I found that if you check fuel correction bank 1, & fuel correction bank 2 along with the A/F ratios that the next time you open the program, the A/F ratios will not be unchecked.
Old Dec 31, 2008 | 01:55 PM
cdoxp800's Avatar
cdoxp800
That is correct. You can change this, you just have to edit the global_options.XML file in the Cipher Dir. I have my setup to pick all the items needed to do e-tuning.
Be careful editing this file if your not sure how to do it.
hulkout
Tuning
Sep 30, 2015 12:33 PM
