What would cause I utec to read lower to acutal PSI
Old Feb 18, 2009 | 05:16 PM
cwylie's Avatar
cwylie
Default What would cause I utec to read lower to acutal PSI
I am seeing 6-7 psi on the utec and 8-9 on the gauge.
Old Feb 18, 2009 | 06:03 PM
UpRev's Avatar
UpRev
What gauge? What sensor on the Utec? One of the two is bad, the only way to check is take it to a shop that has an extra gauge to hook up with and verify.
Old Feb 18, 2009 | 06:48 PM
cwylie's Avatar
cwylie
Autometer gauge. I am pretty sure its the utec because I am running the 3.12 pulley on the vortech which would be about 9 psi.
Old Feb 18, 2009 | 07:33 PM
whoojong's Avatar
whoojong
where do you have the boost reading off of? if they're tapped off of 2 different places, that could be why there's a difference.
Old Feb 19, 2009 | 06:06 AM
cwylie's Avatar
cwylie
Nope. Both tapped from the same source. I think the map calibration is off.
Old Feb 19, 2009 | 08:01 AM
frankie945's Avatar
frankie945
You do not want to T off the map sensor. When I had that utec and map sensor it read .1 higher then my blitz boost controller. You need to calibrate the sensor. I have extra holes that I drilled in my upper plenum just for the map and the boost gauge.
Old Feb 19, 2009 | 06:47 PM
str8dum1's Avatar
str8dum1
mine are t-d and read the same. ^^.1 psi difference? gimme a break.
unless you have a mechanical boost gauge, which gauge are you going to calibrate from?
boost is not just dependent on pulley size. you could lose or gain 2-4 psi based on the rest of your intake/exhaust path
in reality it doesnt matter as your car is tuned off the MAP sensor.
Old Feb 20, 2009 | 05:01 AM
QuadCam's Avatar
QuadCam
check your utec pressure reading with the engine off. what does it read? it should be pretty close to 0 (at sea level)......unless you live at high altitudes and then, it'll read below 0. oops...just saw you are in Austin.,.......it should be pretty close to 0.
I think the stock UTEC gradient and Intercept # are 112 and 169 (or the other way around.) your map sensor should have come with a calibration card, too. most people leave the stock gradient and intercept values. if your readings are way off, you may want to calcualte your actual gradient and intercept numbers from the values on you calibration card.
Old Feb 23, 2009 | 11:52 AM
Jeremy@Altered's Avatar
Jeremy@Altered
Could also have a small tear in the vacuum line going to the map sensor.
Redo the vacuum lines.
Old Feb 23, 2009 | 05:13 PM
track1z's Avatar
track1z
yep
Old Feb 24, 2009 | 10:08 AM
zerosec's Avatar
zerosec
u need the card to calibrate the map sensor ? i bought a used UTEC and it came with no card....
Old Feb 25, 2009 | 07:29 PM
QuadCam's Avatar
QuadCam
to truly calculate the G&I for your map sensor, you would need the info from the cal card. don't worry though. just use the stock 112 and 169 values.....and then look elsewhere if there is a problem.
apex locator
Jul 23, 2021 02:27 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
