engine "errors"
Old Feb 24, 2009 | 03:45 PM
angelo_balto's Avatar
angelo_balto
Default engine "errors"
Hi guys, at my twin turbo 350Z (using a Haltech Platinum ECU) I've got some "engine errors" showing at my dash (mostly O2 sensor).
My tuner says he can't adjust the stock ECU warnings through the Platinum.. Does it sound right to you?
Old Feb 24, 2009 | 07:58 PM
jonnylaw's Avatar
jonnylaw
check out osiris:
www.uprev.com
Old Feb 25, 2009 | 05:26 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
What are the engine errors?
Old Feb 25, 2009 | 03:58 PM
zerosec's Avatar
zerosec
Check Engine Light ?
Old Feb 25, 2009 | 05:12 PM
rcdash's Avatar
rcdash
LOL engine errors. You can tune the Haltech so you don't get any CELs but it is tough to replicate the stock ECU programming exactly. Especially when you boost!!! Better to use Osiris and just disable the errors which are reported in error.
Old Mar 3, 2009 | 12:22 PM
angelo_balto
yes, check engine light...
Old Mar 3, 2009 | 12:25 PM
angelo_balto
bummer... just got back from Nissan. I get 3 errors:
1) CT valves malfunction...
2) front O2 sensors...
3) back O2 sensors...
When I get the first one, the car raises the idle at 1.500rpm... sounds logical?
Old Mar 3, 2009 | 12:26 PM
UpRev's Avatar
UpRev
Hal@Injected can fix it with our Osiris software. He's done it dozens of times, lots of satisfied customers.
Old Mar 3, 2009 | 12:46 PM
angelo_balto
He fixes the stock ECU? He needs to have the Haltech as well?
And if I change the boost once more, will the errors still be absent?
Old Mar 3, 2009 | 12:54 PM
Dynosty's Avatar
Dynosty
angelo balto, can you get the check engine code numbers? Example "0011". We can reflash your stock ecu to turn off the specific codes (and they will stay off regardless of boost level), but I would like to know what is causing them in the first place and see if we can sort that out.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
