HKS FCON V Pro fuse
Old Mar 19, 2009 | 05:47 PM
G35cTT's Avatar
G35cTT
Default HKS FCON V Pro fuse
Not sure if this was answered but couldn't find anything. Does the Fcon V Pro have some sort of fuse? Just noticed as my car isn't starting that the FCon doesn't even power on as usual.
Old Mar 19, 2009 | 09:08 PM
chopperman's Avatar
chopperman
Do you have any more other information. Like what have you done already to try to find the problem?
Old Mar 19, 2009 | 09:28 PM
Crom's Avatar
Crom
Your car isn't starting at all ?......
Old Mar 19, 2009 | 11:00 PM
G35cTT's Avatar
G35cTT
Found out the FCon wire harness went bad due to water gettin in the car. Found a leak coming inside where my harness is located.
Old Mar 20, 2009 | 07:37 PM
rcdash's Avatar
rcdash
Just noticed your sig: 1.3 bar is a little over 4 psi. That's one hell of a motor making 500+ whp at 4 psi.
Old Mar 20, 2009 | 11:49 PM
G35cTT's Avatar
G35cTT
I don't know how you came up w/ that number but 1.3 bar = 18.8549059, you can use it automatically calculates pretty much anything.
Old Mar 20, 2009 | 11:54 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I am sure Raj was referring to 1.3 bar absolute pressure, which would be 1.3 bar minus atmospheric pressure = ~4PSI.
But I am sure you are running more than that
Old Mar 21, 2009 | 12:04 AM
G35cTT's Avatar
G35cTT
Oh I see haha. I actually have a question for you about the FCon wire harness. If I were to change my harness is that a plug n play install that doesn't involve soldering? I had you guys install the GTM PWR radiator/fan mod so not sure if there's additional wiring?
Old Mar 21, 2009 | 01:11 AM
GTM's Avatar
GTM
If you have external fans controlled by the FCon then you will have additional wiring required.
It won't be too hard though, just take your time and double check all your connections.
-George
GT Motorsports
KOF
Tuning
Sep 30, 2015 04:09 AM
