Need help with POS Innovate LC-1...
Old Apr 11, 2009 | 08:40 PM
SdwysFairlady's Avatar
SdwysFairlady
Default Need help with Innovate LC-1...
I've searched and searched these forums for answers, and all I come up with is COMPLETELY random *** threads..so I apologize if this has been discussed.
I recently installed a Vortech kit on my Z, and installed an Innovate LC-1 which is apparently a piece of. First startup after the install, the gauge just read "7.4" and wouldn't move at ALL, so I installed the LED, and the error code it flashed was Error 8, "Usually damaged sensor".
So I thought, ok thats easy to fix, get a new sensor and my car is on the road! Borrowed a sensor from my friends car, which I KNOW works, put it in my car, fired it up, guess what? Still reads 7.4 (and randomly yet rarely jumps to 21.x)and flashes Error 8 code.
I'm getting incredibly fed up with this LC1, as I am afraid to drive my car not knowing where my A/F is at, and I'd REALLY like to take it out of the garage. ANY help would be greatly appreciated!
Thanks much guys,
-Craig
Old Apr 11, 2009 | 10:14 PM
fstrnldr's Avatar
fstrnldr
First thing is make sure you are calibrating the sensor properly when you install them. Second thing is hook it up to a laptop and make sure it is set to gasoline for the type of fuel you're using. If neither of those fixes the problem, then download the latest firmware off the innovate site, and update the firmware. And if none of those three things works, its probably going to have to go back to innovate for repair.
Good luck
Old Apr 12, 2009 | 08:01 AM
SdwysFairlady
Ok heres where I sit, I have tried calibrating the sensor many a time, I do the calibration, doesn't matter if its in free air or in exhaust gas, I hold the button for three seconds, a few seconds later it jumps to 21.8, then just falls to 7.4 again. I had it working, I just kept calibrating it and the 4th time I did it, it worked for about 5 seconds and sat at around 12.5, then fell to 7.4, and tried it about 20 times again and it didn't work. Calibrate, jump to 21.8, fall to 7.4, over and over and over.
This is incredibly frustrating because my car is DONE! I want to be able to get it on the road, but I'm not gonna trust the tune that's on my UTEC without being able to moniter my A/F.
Unfortunately I don't have a cord to hook up to my computer, but I don't think its the wrong setting...I ordered a cord but it still hasn't shown up.
Old Apr 12, 2009 | 06:01 PM
fstrnldr's Avatar
fstrnldr
as much as i love innovate products, they can be a bit flaky at times. Is this new or used? why don't you have the cable? they always come w/ it new, hopefully you can get it figured out once you get the cable and can see what its really doing.
Old Apr 12, 2009 | 06:12 PM
gmx's Avatar
gmx
I have the same problem I bought one it also show me 7. something I did the calibration
I did everything possible to fix but I couldn’t do anything with it I throw it away
and bought haltech wideband
I hope you find the problem ^_^
Old Apr 13, 2009 | 07:47 AM
UpRev's Avatar
UpRev
Contacted the manufacturer for support yet?
Old Apr 13, 2009 | 09:37 PM
Seb-Specialty-Z's Avatar
Seb-Specialty-Z
Who did the actual install of the unit?
We've had great success with Innovate's line of products throughout the years.
I've typically seen installer\user error when finding problems.
Old Apr 13, 2009 | 09:47 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I have seen lots of guys with issues with them when mine crapped out it was the brain unit it wouldn't read anything and kept showing the ERR code. Most of the ones I have seen fail it was the brain they should replace it under warranty if thats the case.
Old Apr 14, 2009 | 07:56 AM
SdwysFairlady
Haha, actually got it figured out, went over the wiring and everything looked fine, so I just said screw it and bought a new sensor, and now it works fine! Its just incredibly ironic that this sensor worked a week or two ago on my friends cars, and now I try it on mine and its junk. Boo.
Thanks to everyone for their replies, and help!
Old Apr 22, 2009 | 07:11 AM
garage-c's Avatar
garage-c
Innovative widebands are the suck OP. eBay it and get yourself a PLX...
http://www.plxdevices.com/
Old Aug 22, 2009 | 01:20 PM
Fixxxercask's Avatar
Fixxxercask
I am currently having the same issue with mine. I tried to recalibrate it about 100 times and it has not worked. I contacted Innovate and I have tried everything they said and it is not working, so maybe it is a bad sensor like you've got. I have had my wideband on my car for about a year though. Thanks for the input.
Old Aug 22, 2009 | 01:26 PM
binder's Avatar
binder
take the lc-1 off the sensor and clean all the connections. Check and clean all your grounds. When you hook it back up go through the initial startup procedure to heat calibrate then free air cal it.
After a year the sensor could have randomly went bad depending on what type of fuel you run or how rich the car is. O2 sensors are very sensitive and can be damaged easily.
My innovate has had some hiccups but it's almost always somehting with the setup (ground come loose, wire not seated properly in the MTS chain, need a recal)
Old Aug 22, 2009 | 06:49 PM
XChacalX's Avatar
XChacalX
I had the same problem last year and ended up after few months later to connect it to my laptop and i did an firmware update and a reset from the laptop , since then , the unit work Perfect ! never had any problem
Old Aug 22, 2009 | 08:51 PM
binder's Avatar
binder
ya, i think people aren't connecting them to the computer to program them for the car first like it says to.
A fresh install of the firmware almost always fixes the problems. Those programs get messed up very easily.
Old Aug 26, 2009 | 11:52 AM
rcdash's Avatar
rcdash
Innovate support forums are plagued with users frustrated with their wideband hardware. I have a full innovate setup (2 XD16s, auxbox, SSI-4, sensors) and I left off the widebands because of all the issues people were having (seemingly random). I installed a turboXS tuner reg - no problems over 2 years. I have had my Haltech dual widebands for the last year - also no problem.
Sensor life seems to be poor with the innovate hardware - and that's a reflection of that particular design. Too bad sensor life data is not published in articles comparing widebands (where Innovate always come out on top for accuracy).
Old Nov 11, 2009 | 03:53 PM
- bigc -'s Avatar
- bigc -
for those who are using the LC-1, where have you guys installed / attached the head unit?
the extension from the o2 sensor is very short so it looks like the head unit would have to sit on or be mounted very close to the tranny. the sales folks at innovate seem to think that's OK, but i think mounting the 'brain' away from heat & water (battery/brake compartment?) would be much better. thanks
Old Nov 11, 2009 | 04:01 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have this same iussue...I hate my Lc1 now. I bought it because it was supposed to be accurate. Guess Ill have to breakdown and do the software upgrades and set up.
No where would that cable be.....
Old Nov 11, 2009 | 04:08 PM
Sylvan Lake V35
I had mine replaced under warranty it lasted about 2 weeks and crapped out again. The whole thing was uninstalled and completely reinstalled by two different guys. I am would not advise anyone to buy an Innovate mine has worked for a total of 1 month out of the two years i have had it. I had to buy another one so i had something for all of the time mine spends getting warranty work
Old Nov 11, 2009 | 04:51 PM
350z 6spd's Avatar
350z 6spd
I mounted it on top of the transmission crossmember.
Old Nov 11, 2009 | 05:26 PM
- bigc -'s Avatar
- bigc -
^ thanks man. after the previous 2 posts, i'm wondering if I should have just got the PLX AFR module and hooked it up to my multigauge
