Uprev tuned by Advance Power House
Old Jun 21, 2009 | 08:21 AM
spoolin_gt's Avatar
spoolin_gt
Default Uprev tuned by Advance Power House
Car - 2005 35th Anniv.
Mods
-HKS True Dual
-Topspeed TP
-k&n filter
Most cars dynoed at APH on a stock Z with a revup motor usually starts off at around 220-230.
First pull was quite impressive with 250whp and 240lbs/tq with just the mods that I have.
After the tune, my final run ended with 260whp and 249lbs/tq.
The car runs so much smoother and pulls hard up to redline. They also put 3 different maps to run stock, tuned, and valet which will only have the car rev up to 3krpm just in case a dealership, valet parking etc. tries to rip the car.
Old Jun 21, 2009 | 09:40 AM
Nice gains!
Old Jun 21, 2009 | 10:44 AM
freedonutss's Avatar
freedonutss
Almost similiar with mine. Jeez if you bolt on a 5/16 spacer you could have around 265-270 whp. Before mine was tuned I dynoed around 251/238. After tune my numbers were 256/241. I noticed the most gains in the midrange rather then the top end. From the graphs it looks like you gained a bit in the midrange also. Good numbers !
Old Jun 23, 2009 | 09:00 AM
305LOPEZ's Avatar
305LOPEZ
I’m sorry, in no way or from am I trying to jack your thread but I have a simple question pertaining to the valet mood. Is this a setting from factory or after a tune? I ask this question because when I bought my car used I never received a valet key.
Old Jun 23, 2009 | 09:30 AM
spoolin_gt's Avatar
spoolin_gt
after the tune..
Old Jun 23, 2009 | 09:46 AM
305LOPEZ's Avatar
305LOPEZ
Originally Posted by spoolin_gt
after the tune..
thanks, but would you need the valet key in order to be in this mode?
Old Jun 23, 2009 | 02:45 PM
CSF's Avatar
CSF
no...you select the "valet" map if you have one set. Uprev allows you to have up to 5 maps that you can select using your cruise control buttons.
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
