AVERAGE stock 350z dyno numbers??
Old Sep 16, 2009 | 09:34 AM
scotts300's Avatar
scotts300
Originally Posted by PinkHippo350
What numbers are rev-ups making at the wheels?
Local rev-up on the same local dyno made 250rwhp with JWT intake (+0rwhp) and NISMO exhaust (+3-5rwhp), so think 5-10rwhp more than non rev-ups.
Old Sep 17, 2009 | 06:34 AM
maXmood's Avatar
maXmood
Under Boost!
'06 non-rev 5AT @ 210whp on a dynojet
Old Mar 7, 2015 | 03:28 PM
yogipower's Avatar
yogipower
Mine's 2006 6MT and she made 242.7 rwhp, 224.1 rwtq with Dynojet.
Old Mar 8, 2015 | 04:56 PM
24k's Avatar
24k
MY 06 made 250 hp and 226 tq on a dynojet.
Old Oct 4, 2024 | 07:38 PM
Shawnyg_33's Avatar
Shawnyg_33
Does anyone know why i’m only making 243.2whp with almost fbo on my 2006 vqDE non revup makes no sense it was on a dyno jet two i have (intake 3inch, 75mm throttle body, ported manifolds, plenum spacer, lightweight pulley /idler pulley delete kit with isr short tube headers and test pipes and y pipe, 91 octane) is my motor bad or sum??
Old Oct 5, 2024 | 12:53 AM
DarkZ03's Avatar
DarkZ03
You are in the vicinity of where you should be for an AT.
ATs dyno lower to begin with, you only have intake and exhaust essentially.
The TB and porting do next to nothing, the ISR shorties are not the greatest and it doesn't even look like you are tuned?
My previous car made 254 with intake, spacer and exhaust and was a manual for reference.
Old Oct 5, 2024 | 08:00 AM
Shawnyg_33's Avatar
Shawnyg_33
Default my fbo baseline numbers
i read 227whp baseline and then 243.2whp on my 5AT fbo vq35de crazzy with ported manifolds, intake test pipes headers and exhaust stock axle back, lightweight pulley with idler pulley delete, 75 mm throttle body, plenum spacer two what’s wrong with my build and what sensors should i change or maintainence should i do
Old Oct 5, 2024 | 09:47 AM
DarkZ03's Avatar
DarkZ03
Nothing wrong per se, a lot of wasted mods tho.
a lot of those do VERY little for power, even less on a AT.
are you tuned?
Old Oct 5, 2024 | 09:56 AM
Shawnyg_33's Avatar
Shawnyg_33
yeah i’m tuned i was 227whp baseline with all those mods and 243.2 after tune i was in az heat 100degree heat after 1 hour drive to the shop
Old Oct 5, 2024 | 01:46 PM
DarkZ03's Avatar
DarkZ03
I'd say that's within reason, hard to tell without knowing AFR and seeing a dyno. Stock DEs will dyno within 210-230 with a 6MT. Even less with slush box, you want real power you need boost.
Old Oct 5, 2024 | 05:26 PM
Shawnyg_33's Avatar
Shawnyg_33
Default bad tcm
i did get told my Tcm was completely shot out from the transmission shop and i was doing some research supossedly a bad tcm can rob you of 15whp-30whp could that be my issue
Old Oct 5, 2024 | 05:40 PM
DarkZ03's Avatar
DarkZ03
Maybe if it's slipping, fix it, but don't expect power gains. You aren't going to get 6MT numbers, maybe 250-260 tops.
Old Oct 6, 2024 | 02:43 AM
travlee's Avatar
travlee
Master
How many miles on the tired motor?
m_0g
Jun 3, 2021 10:05 AM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
