03-05 Bolt On Base Line dyno numbers
Old Jan 1, 2010 | 01:26 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by SLIdEwAyZ25
The new kinetix velocity plenum just came out less then 5 months ago. (I have it) Berk's matalic cats have been redesigned (i have those) and i believe that these two parts alone would dyno almost 20 more hp then a plenum spacer and test pipes.
(yes i know with the cats you don't gain as much peak power as test pipes but the added tourqe with the HFC's would make up for this on a track)
I had to quote this just so it doesn't disappear
You seem to think you have all the answers already so what is the purpose of the thread? I wish you good luck - seriously
Old Jan 1, 2010 | 01:28 PM
03threefiftyz's Avatar
03threefiftyz
Lets get it started.....................
F
Old Jan 1, 2010 | 02:45 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
that is why i was asking for other people's baseline numbers (considering the 350z ecu can adjust AFR to adapt to after market parts)(yes i know there are many factors like altitude humidity timing and many more but it really shouldnt be that hard to findout what works the best) it should be clear which set of parts works the best together in relation to eachother.
there might not be a single best intake or exhaust but if you have the right parts combined it should create noticibly bigger numbers then anything else and with all the people who have added simple bolt ons to their car there should be a clear answer to which set up works the best together but no one will take the time to actually find out.
so instead of trying to flame this why don't you just actually post some numbers so we can compare stats instead of idea's?
Old Jan 1, 2010 | 02:53 PM
03threefiftyz
For the love of Christ...............punctuation. Mods can I get a lock please......this is causing me to become dumber. I'm dumb enough as is.
Old Jan 1, 2010 | 03:09 PM
Z1 Performance
Former Sponsor
Hopefully you read this carefully. It is not an attack, it is reality.
Nothing is revolutionary about what your bolt ons are relative to anyone else's As such, you're going to end up right in the same range as everyone else has since ~2003. There are years worth of posts that support that. I know you might want to think that your intake manifold is something special or your test pipes (of cats, whatever the case may be) are something new, but the reality is, they are not. You will end up with the same baseline mods pre-tune as everyone else does. Your post-tune #'s will also end up similarly to everyone else's.
With the typical bolt ons (intake, exhaust, test pipes or hfc, a plenum spacer (with or without the earlier style lower collector if you have a revup), minus a tune, you'll be in the 250 whp range, assuming you're using a conventional Dynojet. With a tune, in the 260-270 whp range. These numbers have some variance in them depending on the type of dyno, and some other factors. There are a wide combination of parts that will get you there. None of them are anything new or revolutionary, because they don't need to be.
As far as your supposition that the ecu adjusts fuel itself for certain mods, it has a very narrow range with which to do so. Tuning is essential towards maximizing the gains of any single, or group, of bolt on mods
If you click the link in my signature, you will see I have posted my own #'s over the years. Many others have posted their #'s as well, it just takes a little searching on your end.
What you think is outdated, actually is not. It is just as relevant now as it was whenever the dyno was done. You'll find that they all fall within a fairly narrow range with similar mods.
I would strongly encourage you to read, read, read, as much as you can, before spending (wasting) anymore money. From there, if you want to know where your car baselines, take it to your local dyno and see, post up the results, and then you can let us know if there is something special about your car vs all those who have been there before you.
Old Jan 1, 2010 | 03:15 PM
Z1 Performance
Former Sponsor
And seriously, is it really that much harder to type with some sort of structure? If for nothing else, new sentences/paragraph help you organize your thoughts, and it makes it much easier for those trying their best to answer you, to try to understand what the question is in the first place
Old Jan 5, 2010 | 10:31 PM
screener's Avatar
screener
Instead of throwing poo at each other, just do not reply to these obviously beat to death topics. Make the OP do his own homework, no need to help the lazy.
Old Apr 19, 2024 | 12:37 PM
Shawnyg_33's Avatar
Shawnyg_33
Default Something wrong with your car
Originally Posted by maXmood
mine is 2006 (non-rev) dyno'ed 210whp on a DynoJet without any bolt-ons.. so, with all the bolt-ons, i'd expect it to hit 230-240 max!
230-240 wheel horsepower is baseline 5 speed auto numbers for a completely stock vq35de,if it was dyno correctly your deffinatley have a issue with your motor, I would recommend deffinatley checking your vvt solenoids, checking your gallery gaskets and manifold gaskets and do a tune up something isn’t right
Old Apr 19, 2024 | 12:44 PM
Heel Til I Die's Avatar
Heel Til I Die
14+ years later, I think he's good.
Old Apr 20, 2024 | 06:44 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
5th or 6th necrobump in a week. I have no issue with it but it's weird how cyclical this is. Always a consecutive week or two in a year this happens then bam, silence again. Haha. Then there's that other thread that needs to go necro and never to be resurrected again.
Old Oct 4, 2024 | 07:57 PM
Shawnyg_33's Avatar
Shawnyg_33
Default why are my dyno numbers so low
i have a vq35de nonrevup 2006 with 5speed AT and it’s almost FBO rn i had a stock baseline of 227whp and ended it off with 243whp it makes no sense with ported manifolds 75mm throttle body, test pipes, y pipe, isr shortys, intake , plenum spacer and more
Old Oct 7, 2024 | 04:50 AM
Heel Til I Die
I think your 5 speed AT is holding you back.
350z82
Oct 1, 2015 06:25 PM
