Osiris Question
Old Feb 26, 2010 | 04:26 PM
carlili4190's Avatar
carlili4190
Default Osiris Question
Whenever I look at a thread about Osiris it always says you can switch maps with the cruise control buttons. What if I wanted to keep my cruise control? Can you switch maps with the audio controls on the steering wheel?
Old Feb 26, 2010 | 04:32 PM
cdoxp800's Avatar
cdoxp800
You do not lose the cruise control functions.
From the Osiris User Guide V2 Page 10
The most important feature that UpRev adds to a ROM when it is patched is taking the critical tables that are used for tuning (ie fuel, ignition, throttle, rev/speed limits, etc…) and modifying the ECU software so that it loads these tables into RAM and looks the tables up out of RAM as opposed to the flash memory. This relocation of the critical tables allows for real time tuning (RTT) without the need to reflash the ECU for every adjustment. It also makes map switching possible since the values can be changed on the fly.
Due to limited RAM space on the ECU, there are certain data values and tables that have
Old Feb 26, 2010 | 05:29 PM
hellsoldiers08's Avatar
hellsoldiers08
wow search much. /thread
Old Feb 26, 2010 | 07:11 PM
carlili4190
show me another thread where it says for a fact you dont lose the actual cruise control function....
I looked here but it doesnt say anything about maintaing the cruise control buttons for actual cruise control
Old Feb 26, 2010 | 07:53 PM
*ICE*'s Avatar
*ICE*
i have Osiris and no you DONT lose the cruise control.
To switch maps:
- Hold down Cancel + press down on Accel/Res toogle switch.
- the amount of time you hit the toogle switch will depend on your maps.
Example:
- Cancel
+ Accel/Res 1 time for map one.
- Cancel + Accel/Res 2 times for map two.
- Cancel + Accel/Res 3 times for map three and so forth.
- The cruise light indicator will flash right above the fuel gauge with the correspondence number of your map. 2 flashes for map 2, 3 flashes for map 3 and so forth.
There are 5 maps total. Maps can be customize in any way. My setup are:
- Map 1: Power
- Map 2: Fuel economy
- Map 3: Stock
- Map 4: Valet (RPM will cut off at 3k so those valet driver wont do burn out or joy ride on your car)
- Map 5: Anti-theft (RPM will cut off at 2k)
I usually drive around town with Fuel Economy map.. When I need the power for highway or to run a red light, simply switch to Power map in less than 1 second and INSTANT POWAH!!
Old Feb 26, 2010 | 08:00 PM
cdoxp800's Avatar
cdoxp800
I looked here but it doesn't say anything about maintain the cruise control buttons for actual cruise control
All you ever wanted to know about it here.
https://my350z.com/forum/tuning/2795...rom-uprev.html
and here
https://my350z.com/forum/tuning/3788...ggestions.html
and here
http://uprev.com/faq.php
Old Feb 26, 2010 | 10:27 PM
carlili4190
Thanks guys!
Also if I have an 07 HR with just an HKS exhaust is it worth it to get osiris yet?
Old Feb 27, 2010 | 07:06 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Thanks guys!
If you are planning more mods, such as high flow cats/test pipes and intake, I would wait until those are installed to mess with tuning.
Old Feb 28, 2010 | 04:58 PM
sloppymax's Avatar
sloppymax
Just for clarification, Uprev's FAQ says to hold down the CC toggle and hit cancel for the number of the map you want to select. *ICE* says hold down cancel and hit the toggle based on the number of map you want. I was just curious if it actually works both ways or if their FAQs were misinformed.
Old Feb 28, 2010 | 05:22 PM
*ICE*'s Avatar
*ICE*
yes their FAQ is backward. I know this for a fact! Hold down Cancel and press down on the toggle switch based on your map.
Old Feb 28, 2010 | 05:28 PM
Jairen's Avatar
Jairen
Switching maps video
http://www.youtube.com/watch?v=U3kt_fnS8G0
Old Feb 28, 2010 | 05:30 PM
*ICE*'s Avatar
*ICE*
Originally Posted by Jairen
oh snap, I maybe got it backward I'll check tomorrow when I drive the car. Sorry for the wrong info.
Old Feb 28, 2010 | 06:28 PM
pizzato16's Avatar
pizzato16
Its hold down the toggle switch and hit cancel a designated number for each map.
Old Feb 28, 2010 | 06:33 PM
surfcity40's Avatar
surfcity40
nope
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
