My boosted Z' backs fire and engine stop?
Old Aug 10, 2010 | 12:20 PM
ANIBAL's Avatar
ANIBAL
Default My boosted Z' backs fire and engine stop?
Hi guys,I was driving and my z backfire, lights in the dashboard went off, engine stop.. and I check the fuese for the ecu behind the battery and they are all good, some people tell me to check the crank sensor but even if that was bad it wount prevent the car from starting cause the cam sensor kicks in and the car woud start..I m not getting any spark in my spark plugs though!
I did change the timing belt cover recently and I dint touch, bang anything.
Car was running very good (Boosted) the diagnostic says it was running (lean) and now I cant find the problem.The engine turns fine but it wont start cause im not getting any spark..Im runing with a Reflash comp.
Thank You for your imput!
A.Vega
Old Aug 10, 2010 | 12:34 PM
zen350z's Avatar
zen350z
First off if you replaced a timing belt cover you might want to go back and see what you really replaced because our cars dont have timing belts or their covers...
Old Aug 10, 2010 | 12:48 PM
JCat's Avatar
JCat
LoL
Old Aug 10, 2010 | 01:11 PM
ANIBAL's Avatar
ANIBAL
Listen guys if you are looking to laugh, go to a comedy club.
Im asking for any help here..after all thats what this is site is for.
And for your info..the front cover of the vq were the pullys are, thats your timing chain cover.
Old Aug 10, 2010 | 01:12 PM
ANIBAL's Avatar
ANIBAL
Now can some one pitch in some helpfull info on this matter?
Old Aug 10, 2010 | 01:49 PM
zen350z's Avatar
zen350z
I was only playin man but you can see how that can throw someone off by putting the wrong info? Anyways do you have a code reader? first you need to find out if there are any codes that have been thrown.
Old Aug 10, 2010 | 02:51 PM
ANIBAL's Avatar
ANIBAL
Zen.. The code reader was only saying that the car was running lien..thats it..I think that im on able to read anymore because of my comp being Flashed?
Old Aug 10, 2010 | 03:46 PM
djamps's Avatar
djamps
Check your engine grounds, there are 2 on/around the front cover.
Old Aug 10, 2010 | 03:50 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Ur post is so confusing
Old Aug 11, 2010 | 07:22 AM
ANIBAL's Avatar
ANIBAL
Thank You... Djamps
Old Aug 22, 2010 | 08:00 PM
0jiggy0's Avatar
0jiggy0
Could be a lean misfire? But that wouldnt cause no spark. Are you using a full scanner or just a code reader?
Old Aug 23, 2010 | 06:31 AM
djamps's Avatar
djamps
^^ confirmed by PM by the OP, it was a loose engine ground.
Old Aug 23, 2010 | 06:28 PM
0jiggy0's Avatar
0jiggy0
Cool, at least it was nothing major.
Old Aug 23, 2010 | 08:59 PM
ANIBAL's Avatar
ANIBAL
Thank you guys Djamps was right..ground was loose and cause the ecu fueses to go out!
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
