quick question about ECU
Old Sep 22, 2010 | 08:15 PM
nismo_nate's Avatar
nismo_nate
Default quick question about ECU
hey guys,
i don't know if i put this thread in the right section - mods please move if necessary.
1st question: when tapping onto any ecu wires - can i simply wrap a wire on to the exisiting wire and wrap it with electrical tape? or must i solder it on then wrap?
2nd question: i have a ecm diagram from a 03, is it the same layout as a 05 base?
thanks in advance guys
Old Sep 22, 2010 | 09:55 PM
midz350's Avatar
midz350
For the 1st question: I would solder it on then wrap.
For the 2nd question: I don't think that they are the same. Check the 350z-t-e-c-h forum for the 05 FSM.
Old Sep 24, 2010 | 07:10 AM
binder's Avatar
binder
umm, i think as long as it's a vq35DE non-rev engine the harness should be the same. Go by pin number and not colors though. the vq35 rev up might be slightly different.
always go by pin count though.
as for soldering, you can get voltage drops if you don't have a good connection. I always solder for that reason.
Old Sep 24, 2010 | 09:14 AM
0jiggy0's Avatar
0jiggy0
If there was only 1 place you wanted to solder wires in a car. It would be anything affecting the ecu.
issyz
Jul 2, 2017 03:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
